fast track same as interleaving off?
- Gaming
- Re: fast track same as interleaving off?
21-11-2009 10:23 AM
high guys, recently signed up with plusnet pro and wanted to check i was getting the lowest pings available. the guy on techy support said i was already on 'fast track' and that all pro customers are automatically put om that.
does this mean my interleaving is off?
if i ping bbc.co.uk i get around 48ms although i live in the far north of scotland.
4 REPLIES 4
21-11-2009 10:37 AM
sure they didnt say fastpath?
48ms from north of scotland is possablely fastpath.
what router do you have, most will report the interleaving status
tells me on my dg834g v4 netgear by using routers telnet info, channel: fast
Quote # /usr/sbin/adslctl info --stats
/usr/sbin/adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 856 Kbps, Downstream rate = 3683 Kbps
Link Power State: L0
Mode: ADSL2
Channel: Fast
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 11.4 4.5
Attn(dB): 50.0 28.2
Pwr(dBm): 0.0 12.5
Max(Kbps): 4116 840
Rate (Kbps): 3683 856
21-11-2009 11:48 AM
hey man, they probably did say fastpath. i guess that's the same as interleaving off then?
my router is the thomson one plusnet supplied. it dosen't seem to report that stat.
thanks
thanks
21-11-2009 3:26 PM
yep interleaving off is normaly reported as fastpath http://www.kitz.co.uk/adsl/interleaving.htm
you may have to telnet into it using this command here http://community.plus.net/forum/index.php/topic,80792.msg659208.html#msg659208
21-11-2009 10:06 PM
Great!! just been able to check mine , thanks asbo
