connecting to xbox live through wireless
jakereed999666
Can't seem to manage to connect to xbox live through plusnet. I've put all the codes in still can't connect. Has anybody got any tips?
1 REPLY 1
Steve
Seasoned Pro
Re: connecting to xbox live through wireless
Welcome to the forum, more details required, What router are you using? Have you other equipment managing to connect wireless? Are you using wireless G-B-N? What do you mean by codes? portforwarding? UPNP enabled?
If life gives you lemons, make lemonade.
