changing interleaving off
- Gaming
- changing interleaving off
19-12-2015 10:08 PM
Thanks, Zain
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Re: changing interleaving off
21-12-2015 3:21 PM
21-12-2015 9:03 PM
dick:quote
22-12-2015 1:31 PM
Can you open a command prompt and type in 'ping bbc.co.uk'
It should give some results like this:
Pinging bbc.co.uk [212.58.244.22] with 32 bytes of data:
Reply from 212.58.244.22: bytes=32 time=8ms TTL=53
Reply from 212.58.244.22: bytes=32 time=9ms TTL=53
Reply from 212.58.244.22: bytes=32 time=7ms TTL=53
Reply from 212.58.244.22: bytes=32 time=11ms TTL=53
Ping statistics for 212.58.244.22:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 7ms, Maximum = 11ms, Average = 8ms
22-12-2015 11:15 PM
Reply from 212.58.246.79: bytes=32 time=10ms TTL=56
Reply from 212.58.246.79: bytes=32 time=40ms TTL=56
Reply from 212.58.246.79: bytes=32 time=30ms TTL=56
Reply from 212.58.246.79: bytes=32 time=136ms TTL=56
Ping statistics for 212.58.246.79:
Minimum = 10ms, Maximum = 136ms, Average = 54ms
30-12-2015 12:11 PM
Could you do this again with 'ping -t bbc.co.uk' and let it run for around 50 results (Then Ctrl+c to stop it running) so we can see how often it's jumping up.
Thanks.
02-01-2016 4:53 PM
Reply from 212.58.244.23: bytes=32 time=19ms TTL=56
Reply from 212.58.244.23: bytes=32 time=53ms TTL=56
Reply from 212.58.244.23: bytes=32 time=17ms TTL=56
Reply from 212.58.244.23: bytes=32 time=18ms TTL=56
Reply from 212.58.244.23: bytes=32 time=132ms TTL=56
Reply from 212.58.244.23: bytes=32 time=452ms TTL=56
Reply from 212.58.244.23: bytes=32 time=140ms TTL=56
Reply from 212.58.244.23: bytes=32 time=36ms TTL=56
Reply from 212.58.244.23: bytes=32 time=243ms TTL=56
Reply from 212.58.244.23: bytes=32 time=60ms TTL=56
Reply from 212.58.244.23: bytes=32 time=22ms TTL=56
Reply from 212.58.244.23: bytes=32 time=96ms TTL=56
Reply from 212.58.244.23: bytes=32 time=101ms TTL=56
02-01-2016 6:13 PM
03-01-2016 1:41 AM
03-01-2016 10:10 AM
03-01-2016 2:17 PM
Thanks.
03-01-2016 2:27 PM
03-01-2016 6:32 PM
03-01-2016 7:02 PM
Thanks.
05-01-2016 6:07 PM
Any advice would be appreciated, Thanks.
