can wmm be turned off on technicolor tg582n
ghos7em1
can wmm be disabled by telnet?
4 REPLIES 4
Oldjim
Fixes: 63
Re: can wmm be turned off on technicolor tg582n
for my benefit what do you mean by wmm as all I found is this http://en.wikipedia.org/wiki/Wireless_Multimedia_Extensions
ghos7em1
wmm is qos for wireless,i found a way through telnet.wireless qos config mode=disabled
chrisgrech
Hi ghos7em1,
I am trying to figure out how to disable WMM on my router "technicolor TG589VN". I am using cyberduck on my macbook.
Is it possible to help me out on this one? thanks
ejs
Aspiring Hero
Fixes: 25
Disabling WMM is generally the wrong thing to do, because disabling WMM tends to also disable all 11n wireless speeds and features.
