bandwith usage xbox
- Gaming
- bandwith usage xbox
bandwith usage xbox
05-12-2007 4:07 PM
would be helpful.
thinking of getin bac in to xbox gaming an want to know if to move to a unlimted deal or to stick usage limits.
Re: bandwith usage xbox
05-12-2007 4:31 PM
Depending on the game, you would probably be looking at a ballpark figure of around 50MB per hour.
05-12-2007 5:04 PM
would b nice to hear from a none plus net staff member on this matter as they would hav no motvie to keep me on plus net.
05-12-2007 5:09 PM
Average usage on my account is between 200-300mb/day, which equates to 50mb/h This includes two Teamspeak clients running.
I can't see that an Xbox would be more than this.
B.
05-12-2007 5:11 PM
My answer came striaght from google, so not a personal opinion, but merely an answer I got from using a search engine
Besides, I'd certainly have nothing to gain from lying to you!
05-12-2007 7:45 PM
so appoliges to u
06-12-2007 10:09 AM
I think I had a quick look at your account yesterday and asked Dave to try to sort things out for you. Given that you account is currently showing zero usage, I reckon he might have sorted it. Let me know if it's still showing no usage tomorrow and I'll get someone onto it.
06-12-2007 12:55 PM
leave a quick note tomoz say if its sorted.
back to the start of this topic iam now wondering if i will need to invest in a new router to get an xbox connected.
currnetly got the free voyager 210 router.
done abit of googlein but it dont say owt bout my router jus that bt routers r genaraly o.k
06-12-2007 12:58 PM
Are you connecting your router to the computer by USB?
If so, you could connect the XBOX to the router using an ethernet cable (if they're close enough to each other).
06-12-2007 3:56 PM
as for xbox my router is at the other end of the room to the t.v with no options to move the 2.
had a quick look for long usb or ethernet cables but max was 3meters and im not a big fan of wireless routers.
hav u any knowledge of long ethernet or usb cables over 10m probally would do.
06-12-2007 4:09 PM
