add Dungeons & Dragons Online®
Blim
hi
could you add Dungeons & Dragons Online® to the game list and management systems. Im getting dc'ed every time i join or leav and instant.
I could be more but ive got my computer setup as dnz and public ip device.
thanks.
Its a steam game, free to play. here is a link to the problem im getting.
"connection to server was lost"
http://support.turbine.com/ics/support/KBAnswer.asp?questionID=570&hitOffset=2575+2572+2532+2526+251...
15 REPLIES 15
Oldjim
Resting Legend
Fixes: 63
Re: add Dungeons & Dragons Online®
have you checked the classification using Wireshark
Blim
its not on th your games list and as i only get one day off i was hoping one of you could do this or at least verify if it should be working?
Oldjim
Resting Legend
Fixes: 63
It is unlikely to be picked up until Monday
Blim
Bronze 0x20 or 0x00 Non-interactive traffic
should it ever be this low?
Blim
just loaded up bf3 and the same
0x00
no wonder I cant play game online....
I can see a fat refund!
Oldjim
Resting Legend
Fixes: 63
It appears to be classified as P2P assuming you are on extra
The only quick way to fix it is to add the Pro option which takes place almost immediately and can be removed at the end of the billing month
Regarding BF3 is that the upstream you are seeing as that is always 0x00 as it isn't throttled in any way
Kelly
Fixes: 9
bf 3?  As in battlefield 3?  We definitely have a signature for that.
Kelly Dorset
Ex-Broadband Service Manager
Blim
Oldjim
Resting Legend
Fixes: 63
That is upstream and isn't relevant
Blim
everything on the list is sying 0x00 or 0x20, one saying 0x80 but thats no voip or gaming triffic
Gus
DnD has the same profile as Lotro so its covered, but they do some weird protocol changes, it uses UDP to check servers etc but once in game its HTTP
edit: In detail how the game connects at this link
http://forums.lotro.com/showthread.php?465900-Time-Warner-RoadRunner-Brighthouse-players-please-read...
They have a very buggy inhouse forum, so it will probably not load so hit refresh a few times
FTTP 500 regrade from Tues 28th November
Blim
I added the pro addon
is it somthing to do with the port still in use with the udp when its trying to now use it in http?
well what ever it is, its making the game unplayable and its to do with pn's network as i dont use firewalls.
Kelly
Fixes: 9
Are you still having problems with Pro?  You shouldn't be.
That graph looks fine btw.
Kelly Dorset
Blim
nope still playing up.
