about interleaving - stats included
max99
so i asked plusnet support if my interleaving was off or not.  here's the reply i got:
Thanks for your query
According to the DLM (Dynamic Line Managment)  the interleaving is off (FAST) and this is causing the Sync rate to drop as the SNR is increasing, would you like us to switch this on or keep it as is?
15 records found
BRAS Profile Name Headline Rate-Downstream Line Rate (KBPS) Downstream Line Rate Timestamp Maximum Stable Rate (KBPS) Fault Threshold Rate (KBPS) Maximum Stable Rate Re-set (Y/N) Below Threshold (FTR) Speed TimeStamp Noise Margin Run Mode Noise Reset Run Mode Change Profile Change Time Interleaved Indicated Line Quality ILQ Change Service Level DSLAM Override BRAS Override Mean Time Between Errors Downstream ( Seconds ) Mean Time Between Errors Upstream ( Seconds ) Mean Time Between Retrains ( Seconds ) Uptime (Seconds) No. of Retrains in 24 Hour SYNC Rate(Current Minimum Line Rate) Delta Sync TimeStamp Product Name
adsl4000 1 25-11-2009 17:23:42 5120 4096 N Y 23-11-2009 02:00:53 2 Fast N N 22-11-2009 11:55:53 A A N 223 7855 86400 86400 0 4544 25-11-2009 17:23:42 EUAC
adsl4000 1 25-11-2009 17:23:42 5120 4096 N Y 23-11-2009 02:00:53 2 Fast N N 22-11-2009 11:55:53 A A N 223 7855 86400 86400 0 5120 22-11-2009 21:29:15 EUAC
adsl4500 1 20-11-2009 17:42:35 5120 4096 N N 23-11-2009 02:00:53 2 Fast N N 22-11-2009 11:55:53 A A N 223 7855 86400 86400 0 5120 22-11-2009 21:29:15 EUAC
the guy is asking of he should turn it on due to sync speed?
i'd rather have the lower ping but don;t know much about these stats.  anyone more in the know care to comment?
cheers Smiley
15 REPLIES 15
scootie
Re: about interleaving - stats included
can you grab your line stats from your router please http://www.kitz.co.uk/adsl/frogstats.php
i run fastpath on a 50db attention line with a 3000kbps profile, am the same i would rather run my line 500kbps lower to enable fastpath to run decent on my long line
below my stats for my adsl2 fastpath line, my line actualy runs 500kbps better than that but the 21cn dlm in its wizdom decided to band my sync rates so cant sync here than that at the moment
max99
hi man,
my attenuation is 52, my SN is 6.5
max synch 5,112
on speed test i get around 3.8 Mbps down / 0.36 Mbs up
i'm happy with those speeds, i just want to minimise my pings Smiley
if i ping bbc.co.uk i get averages of 37ms...is that good?
Euge
Depends on which part of the country you reside in Max, if you live in the northern reaches of Scotland then I'd say it's pretty good but if you're just outside London then I'd say that you have interleaving on or there are other issues.
max99
i do in fact live in northern scotland Smiley
i guess i should be happy with those pings then...i can say that my online gaming feels much better since i switched from orange Smiley
scootie
just south of sheffield, fastpath
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=19ms TTL=122
Reply from 212.58.224.138: bytes=32 time=16ms TTL=122
Reply from 212.58.224.138: bytes=32 time=17ms TTL=122
Ping statistics for 212.58.224.138:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 16ms, Maximum = 19ms, Average = 17ms
matt_2k34
Pinging 212.58.224.138 with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=41ms TTL=122
Reply from 212.58.224.138: bytes=32 time=39ms TTL=122
Reply from 212.58.224.138: bytes=32 time=40ms TTL=122
(Just for reference) - those are mine on a 3.5 meg line (with interleaving) - im probably about 40 miles closer to the source (london) and im what, 22+ ms slower than asbo
max99
here's mine from the north of Scotland:
PING bbc.co.uk (212.58.224.138): 56 data bytes
64 bytes from 212.58.224.138: icmp_seq=0 ttl=122 time=38.452 ms
64 bytes from 212.58.224.138: icmp_seq=1 ttl=122 time=36.967 ms
64 bytes from 212.58.224.138: icmp_seq=2 ttl=122 time=37.012 ms
64 bytes from 212.58.224.138: icmp_seq=3 ttl=122 time=36.759 ms
64 bytes from 212.58.224.138: icmp_seq=4 ttl=122 time=37.841 ms
64 bytes from 212.58.224.138: icmp_seq=5 ttl=122 time=37.739 ms
i'm on a mac...notice my ping is 64 bytes of data (not 32)...wonder if that makes a difference?
scootie
not intill you start getting over 500bytes does it start getting alot higher
C:\Users\SparrowHawk>ping -l 64 bbc.co.uk
Pinging bbc.co.uk [212.58.224.138] with 64 bytes of data:
Reply from 212.58.224.138: bytes=64 time=17ms TTL=122
Reply from 212.58.224.138: bytes=64 time=16ms TTL=122
C:\Users\SparrowHawk>ping -l 500 bbc.co.uk
Pinging bbc.co.uk [212.58.224.138] with 500 bytes of data:
Reply from 212.58.224.138: bytes=500 time=23ms TTL=122
Reply from 212.58.224.138: bytes=500 time=22ms TTL=122
C:\Users\SparrowHawk>ping -l 1000 bbc.co.uk
Pinging bbc.co.uk [212.58.224.138] with 1000 bytes of data:
Reply from 212.58.224.138: bytes=1000 time=31ms TTL=122
Reply from 212.58.224.138: bytes=1000 time=29ms TTL=122
Reply from 212.58.224.138: bytes=1000 time=30ms TTL=122
w23
Fixes: 4
just out of interest Max,
does www.pingtest.net offer any decent results (from a nearer server)?
What I'm not at all sure about is whether your conection has to travel from your locality down to the PlusNet physical network then back again.
Call me 'w23'
max99
i get about 40-50ms on average but no servers show up in scotland.
overall i'm pretty happy however one weird thing i'm noticing is after 11.30pm or midnight my pings get quite erratic.
has anyone else experienced this?
scootie
max are you on 21cn adsl2+ product?
if so you will find this to be your issue your getting after midnite till about 1-2am http://community.plus.net/forum/index.php/topic,80166.0.html
@walker. yes every ones traffic on PN has to travel across BTw's network then across the central's (20cn) / host links (21cn) to end up at the gateways in london http://www.plus.net/support/network_performance/broadband_packets_drop.shtml
where it will then make its way across the PN routing to find its way to the  destantion
there is a handy drawing of the layout of the telehouse sites in london to show what path your traffic takes some where but for life of me cant find it, i think jelv knows where it is am sure he will point you to it to give you a clear picture how traffic is routed
max99
Quote from: ASBO
yes mate, i'm on adsl2+.  this is really bizarre, sort of like the opposite problem i had with orange when peak gaming was horrible. and everything sped up at midnight.
just for reference for the tech guys who may be reading:  i get solid 37ms ping to bbc.co.uk peak times, then after midnight it jumps all over the place.
would be nice if this could be sorted as i game allot into the wee hours, especially at weekends Smiley
scootie
me to max. they have tried a few things to get it sorted and sent the results of anything they have tried to the vendor of the hardware ect.
there should be some more 21cn cappicty added this week which should improve things for abit.
p.s i play battlefield 1943 and dont notice the lag in that game much
jelv
Fixes: 10
Quote from: ASBO
You want the Our Network link at the bottom of every page on the members portal. From there you want the Technical Information link.
For an explanation of how ADSL (at least the 20CN version) works I suggest a look at Kitz's pages starting with http://www.kitz.co.uk/adsl/equip.htm
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
