Your way Pro - ?
- Gaming
- Your way Pro - ?
Your way Pro - ?
25-06-2011 9:37 PM
Have had 3 tickets on the go from the 8th of June or so - I keep getting high latency and reduced speeds in the evenings only - Playing FPS games this is really poor especially when I have verified with Plusnet its not an issue at my end/equipment. Any other gamers not getting what they have paid for during the evenings - I have been problem free since swapping to plusnet from Sky till now. Ping spikes of above 600ms sometimes with a normal 6.60mps d/l line that drops to <2Mps
Still waiting for a resolution....
Anyone else had this and got it sorted?
jim:red all caps removed from title as per forum rules mod:end
Re: YOUR WAY PRO - ?
25-06-2011 9:45 PM
It might be worthwhile asking Plusnet to remove Interleaving from your line If not already done so?
25-06-2011 10:06 PM
I have seen no change since - Getting pings of 600ms tonight on Blacks ops pc - but everything is slowed internet, ventrilo....I aint a happy peak time user anymore. 1930 tonight was getting 40-50ms ping with 6.60mps dl - now its anywhere from 50-650ms god knows what the speed is...its not 6.60Mps
25-06-2011 10:07 PM
25-06-2011 10:18 PM
Re: Your way Pro - ?
26-06-2011 12:53 AM
As for the exchange it has not yet been mentioned by anyone...tbh I would have expected that to have been checked by plusnet.
Have done ping tests, path pings, tracerts, wireshark (correct data assignment - titainium), bt speedtests, speedtest.net...Line checked for loops and corrected, Tested via master socket, and with everything i can connect to the line and get the same results. Router reset, security checked
I only get an issue between say 19:00 and 22:30...all other time its is spot on 35ms ping 6.60 mbs d/l. Its not a fault with my gear as its too consistent regarding the occurence time.
It screams to me contention ratio or throttle...but I should not be throttled on the Your way pro.
I just want to know what on earth it is - I appriciate the advice guys i'm was just wondering if its happening to me is there anyone else out there getting similar - Location is Market Weighton, East yorks approx 1 mile form the exchange.
26-06-2011 11:05 AM
26-06-2011 11:24 AM
26-06-2011 6:05 PM
I hope so - it was mentioned that the gear in exchange may be running hot at peak load...so will be just waiting on BT then? Oh boy
27-06-2011 9:38 AM
I have emailed our suppliers to have your VP checked as you have indicated this may be a peak time occurrence. I will contact you again once we receive a reply. I have also updated your fault ticket to this effect.
Jojo
Thanks for the nice comments guys
27-06-2011 8:18 PM
29-06-2011 5:39 PM
However for most of the peak period yesterday eveing i was getting more high latancy >100ms - 500ms. Checking my speed via BTspeedtest and speedtest.net confirmed issues - 3.3Mbs on bt and 0.94Mbs, 3.4Mbs when on speedtest.net
This is on a setup that was giving 35ms ping 6.6Mbs before and after the peak period - according to speedtest.net
I shall monitor again tonight assuming the Plusnet line checks may have impacted on my results - however as they are so simialr to the results i have been getting for 3+ weeks now i dont think anything has changed.
Is someone else nicking my bandwidth on a evening?
29-06-2011 6:10 PM
29-06-2011 6:19 PM
30-06-2011 10:56 AM
