Xfire login issues
stevyd10
Xfire login issues
Hey,
I have run into a problem with he latest version of xfire and that it doesn't let me login(it just times out or looses connection). I have already pulled this up on the xfire forums but i think it is something more involved.
I couldn't ping cs.xfire.com and then when i tried to do a tracert it did about 5 routers before timing out. Do you thing PN has gone and banned connections to xfire? Can anyone with PN internet login to xfire and this is only a problem to me? Also if it is a routing problem is there any way I can force a route to the xfire servers?
Thanks for any help, (I really cannot live without xfire!!!)
2 REPLIES 2
Gus
Re: Xfire login issues
You can't ping cs.xfire.com as it blocks ICMP's, it's hosted in USA so guessing weekend speed issues there.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
stevyd10
Thing is i have never had this problem before and also all my friends can connect. It sounds a bit like a routing issue but i am no expert. Grin i'll just keep looking at the xfire forums.
Moderators note by James_H : Removed full quote of previous post - it is not needed in this instance. : link:rules
