XboxLIVE
- Gaming
- XboxLIVE
XboxLIVE
13-01-2008 5:44 PM
I've asked people about this and they mentioned about going into settings to check my NET to see if it said Open or Moderate. Its at Open so anyone know the reason why I'm having trouble?
Re: XboxLIVE
13-01-2008 5:49 PM
Bear in mind that if your connection is being used for other things when you are gaming (eg surfing or downloading) then the connection will be slowed.
Hope that helps,
Re: XboxLIVE
13-01-2008 6:03 PM
I only play a few games online, PGR4 and COD4, only a few times has my connection been bad on COD4 that I've had to restart the PC. As my xbox connection goes thru my PC.
I don't download anything while I'm playing, its normally just sitting idle. I'll look at browsers every now and then but I always close them before playing again.
Outside the gaming I've had no problems with plusnet for a couple of years.
[Moderator's note by Peter (PJ): Please do not quote the previous post in full as per the link:rules]
Re: XboxLIVE
13-01-2008 8:10 PM
Re: XboxLIVE
13-01-2008 8:19 PM
Re: XboxLIVE
14-01-2008 10:02 AM
Is PGR4 much of an improvement?
Equally, I've never had any issues with XBL - All I do is plug the ethernet cable into my router and it works a treat.
Re: XboxLIVE
14-01-2008 11:59 AM
Re: XboxLIVE
14-01-2008 1:38 PM
Re: XboxLIVE
14-01-2008 4:08 PM
Quote from: sophos9 Can you elaborate on the Xbox goes through my PC, do you mean that its piggy backed in some way?
The cable goes into a USB connector in the back of my PC, which is how I'm able to get onto xboxlive.
It's nothing to do with the recent bad form of xbox, as I had the lag problem well before xmas, some 2 months before actually. But recently its been really bad.
Re: XboxLIVE
14-01-2008 4:09 PM
Quote from: Jameseh I thought PGR3 was a cracking game (and yes, I was probably as bad as Liam).
PGR4 is better, it's not as fun as the online play in PGR3 though. The bikes vs car thing is good.
Re: XboxLIVE
14-01-2008 4:28 PM
Quote from: BugsyMalone The cable goes into a USB connector in the back of my PC, which is how I'm able to get onto xboxlive.
Ahh so you have a integrated usb adsl modem? Personally I would junk it a buy a router, dead cheap second hand off eBay
Re: XboxLIVE
15-01-2008 11:45 PM
Re: XboxLIVE
17-01-2008 10:32 AM
Quote from: sophos9
Uses ICS in Windows.
Re: XboxLIVE
24-01-2008 6:02 PM
Best £45 I ever spent... Oh there was that one time in that brothel....
Cheers plusnet guys for looking into my account and cheers to all the replied.
