Xbox connection problems.
- Gaming
- Xbox connection problems.
25-10-2009 12:15 AM
I'm playin fifa 10 and for the past few days my connection has been crap. It had 1 day in between where it was a full connection but now its on 1 red bar
Need help, its ruining my gaming
Re: Xbox connection problems.
25-10-2009 12:48 AM
are you adsl2+ ex trail or the normal adsl?
what package you on and have you gone over your usage allowence?
whats your pings like from your pc to say bbc.co.uk?
will say its first time ive seen an xboxer moan about this game its normaly the ps3'ers
25-10-2009 1:02 AM
26-10-2009 1:39 PM
I'm on the basic package
Not over my usage
and when I do pings on my computer on speedtest.net they seem to be fine at like 50 or so and less
It has been mint for the 1st three months, so I don't see why there is a problem. I'm going to see what call of duty WaW is like tonight, just to make sure its not just Fifa.
26-10-2009 1:44 PM
is it all day your having issues or is it worse an better at diffrent times of the day.
good idea to see if its a plain issue with fifa or not
28-10-2009 8:17 AM
28-10-2009 12:35 PM
I can tell if its a bit poo as on the screen where you ready up and pick a position it takes 4-5 seconds which is instant if everything is ok.
28-10-2009 2:11 PM
28-10-2009 6:20 PM
05-11-2009 9:35 PM
05-11-2009 9:38 PM
What happens if you do a tracert on bbc.co.uk?
05-11-2009 9:47 PM
05-11-2009 9:52 PM
then type 'tracert bbc.co.uk'
C:\Documents and Settings\Administrator>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms voyager.home [192.168.1.1]
2 26 ms 25 ms 29 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 82 ms 18 ms 17 ms vl604.thn-gw1.plus.net [84.92.4.169]
4 17 ms 17 ms 19 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 26 ms 29 ms 20 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 46 ms 29 ms 114 ms 212.58.238.149
7 20 ms 19 ms 124 ms bbc.co.uk [212.58.224.138]
Trace complete.
05-11-2009 9:54 PM
Click Start -> Run. In the box that appears, type "cmd" and press enter. In the black window that appears, type "tracert bbc.co.uk" and press enter. Let it run it's course, then right click in the window, and click Mark. Highlight the text, press Enter to copy to the clipboard, then paste it here.
On Vista / W7:
Click Start. In the search box, type "Command Prompt" and open the Command Prompt from the list of results that appears. In the black window that appears, type "tracert bbc.co.uk" and press enter. Let it run it's course, then right click in the window, and click Mark. Highlight the text, press Enter to copy to the clipboard, then paste it here.
EDIT: Looks like Euge beat me to it
05-11-2009 9:55 PM
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\MiniUser>tracert bbc.co.uk
1 3 ms 1 ms 1 ms home [192.168.1.254]
2 40 ms 38 ms 38 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 40 ms 36 ms 37 ms gi2-2-204.ptn-gw02.plus.net [84.92.3.93]
4 58 ms 40 ms 38 ms te2-2.pte-gw2.plus.net [212.159.1.106]
5 43 ms 36 ms 62 ms vl23.thn-gw2.plus.net [212.159.4.20]
6 190 ms 231 ms 222 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 89 ms 42 ms 64 ms 212.58.238.149
8 44 ms 41 ms 38 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
