Xbox One in DMZ but has strict Nat
ashmatuk
I have an issue where my Xbox one has strict Nat even though I have put it in the dmz. The only way to get an open nat is to reset everything, but it changes back to strict after a day or two.
Router is a Thomson 585v7 - can anyone advise?
Thanks  Smiley
ghos7em1
Re: Xbox One in DMZ but has strict Nat
after you have reset router do you put console back in dmz? sounds like it could be getting different ip.check on router you have ticked always use same ip.
ashmatuk
Thanks, will try that  Smiley
