Xbox One S on Plusnet Hub One
alexsanders94
@JonoH
Hoping you can help! Read a thread from a couple of years ago where you added a static IP so that someone could get their Xbox to connect and I'm having a similar issue.
The hub is a Plusnet Hub One, and despite adding a static IP to the Xbox One S, I cannot get it to connect to the internet wired or over wireless. Any suggestions?
1 REPLY 1
alexsanders94
Re: Xbox One S on Plusnet Hub One
Edit - Its a Series S and UPnP is enabled, port forwarding done and DMZ enabled also..
