Xbox One Remote Streaming Ports...
- Gaming
- Xbox One Remote Streaming Ports...
10-04-2017 4:11 PM
I've got the plusnet router "plusnet hub 1" that is a rebranded BT Hub5
now, trying to setup the following ports to allow remote streaming.4838, 5050, and 49000-65000. now, i don't know if they need to be set as UDP or TCP, so have gone for both, but i can't set the 49000-65000 as it says that there is another rule that conflicts. but there is nothing that i've setup that is anywhere near this range. now, i can get 49000-53662, but if i include 53663, i get the conflict.
a little digging about seemed to say that upnp was the culprit, so have switched that off, but no change in if i get a conflict in that port range. any ideas?
cheers,
Re: Xbox One Remote Streaming Ports...
29-11-2017 2:09 PM
