Xbox – Midnight cut-off blues, can you help?
- Gaming
- Xbox – Midnight cut-off blues, can you help?
18-09-2010 1:11 PM
If I am using my Xbox at midnight without fail on the stroke of midnight I get the message that I have been disconnected from Xbox live, if I am in the middle of a multiplayer game I am screwed and have to log back on to live. It’s bloody annoying and I can’t work out what is causing it.
There doesn’t appear to be a setting on the Xbox that would cause it and I know folks (living just half a mile away, using the same exchange) that don’t have the issue who are also plusnet users.
So I can’t see that either my Xbox or plusnet are causing the problem, there’s nothing I can see in the router (Netgear DG834N) that would interrupt the connection at midnight either, any ideas?
Re: Xbox – Midnight cut-off blues, can you help?
18-09-2010 4:48 PM
19-09-2010 10:10 AM
19-09-2010 1:14 PM
19-09-2010 1:15 PM
Have you got anything electrical near the router that might switch on/off or even switch to a low-power state around about midnight? or is your router near your thermostat? I have recently helped a client to stop her midnight cut-offs (she was on talktalk :-/), the poblem turned out to be her thermostat (old type with manual switch time controls). Her Master socket and router were directly beneath it, so, a quick change of position for her router and, hey presto, no more problems
Even sky checking for updates can cause the connection to cut out (I know this from personal experience). If you have sky plugged into your phoneline, i would be tempted to remove the extension from the skybox for the night to see if that helps.
Hope this helps,
kris
19-09-2010 1:33 PM
19-09-2010 1:38 PM
See here for all sort's of help http://www.unofficialguidetolive.co.uk/
19-09-2010 1:43 PM
Quote from: Steve What router are you using?
are you using wireless or ethernet with your router?
cheers
19-09-2010 2:09 PM
I just set the time zone to give me ‘midnight’ at 2pm and bingo I was disconnected. So I just need to set my time zone to give me midnight at some ungodly hour in the morning, 4 am should do it!
It would still be nice to know what is happening but basically it is fixed and hopefully anyone else with a DG834N router doing the same will find this thread by googling.
Thanks for all the suggestions.
19-09-2010 2:38 PM
I have a DG834N v1 (with DGteam firmware)
and I regularley play PC games online over midnight, and have not experienced any problems.
Have you got any other settings in the router that might be causing the problem?
for example, there is an option to turn to turn the wireless on and off on a schedule.
19-09-2010 2:42 PM
It is a known problem with the DG834N. It is the wlan uptime timer resets itself to 0 every 24hrs at midnight. As far as I am aware, there has been no fix issued by Netgear, so customers are advised (as you have done) to change timezones so that midnight falls at a time that is convinent for yourself (4am?)
cheers,
kris
