Xbox Live Problems
- Gaming
- Xbox Live Problems
Xbox Live Problems
18-08-2009 10:16 PM
I have recently purchased Xbox Live to take advantage of the online features. I have connected the xbox to my router (wired) and ran the Xbox live Connection test which was successful. Xbox live connects fine on the dashboard, sending messages / downloading demos etc however when I attempt to play certain games on line it disconnects within 5 seconds (this occurs on both Fifa 09 and Gears of War).
My router works fine on my laptop and two desktops and on the Nindendo Wii however it is not operating correctly on the xbox. After contacting Xbox Support they have suggested it is an issue with my ISP.
When playing online, I have ensured that the Xbox is the only connected device on the network. The router (Netgear DG834 version 1) has the latest firmware. I have also enabled port forwarding and turn on UPNP but to little success. In the last few days I have turn off interleaving and turned off the firewall which has made no difference.
Are there any further suggestions or changes that I can make?
Hope you can help,
Thanks in advance,
Russ Lawson
Re: Xbox Live Problems
18-08-2009 10:28 PM
i run a dg834g v4 and have no issues with XBL
18-08-2009 10:32 PM
Thanks for the suggestion!
18-08-2009 10:35 PM
whats your mtu set at on the router?
18-08-2009 10:39 PM
18-08-2009 10:58 PM
Fifa usually lasts 10-15 seconds and Gears of War simply says a disconnect message.
MTU = 1458
It's a very odd problem!
Have fun on Battlefield!
18-08-2009 11:52 PM
When you get booted out of games, is it only the game that disconnects, or do you get booted off of Xbox Live altogether? Are you connecting via a Wired or a Wireless connection?
19-08-2009 7:15 AM
it is wired straight into the router with the latest firmare.
thanks for the reply!
19-08-2009 7:26 AM
any chance of borrowing a newer version router to see if you get the same results?
19-08-2009 12:32 PM
I turned off NAT out of interest and it did raise an error so I turned it back on.
I am struggling to get hold of an ADSL router at all. Most people I know seem to be on cable.
19-08-2009 1:27 PM
I would agree with Asbodog - it sounds like more of a router problem, rather than a problem at Plusnet's end.
Out of interest, which Plusnet package are you on? Do you have the Broadband Firewall enabled in the Member Centre control panel?
Edit: Just had a thought - what are your Firewall settings on the Netgear router? You might want to try temporarily enabling the "Disable Port Scan and DOS Protection" option on the "WAN Setup" screen, if you have it?
19-08-2009 6:59 PM
Quote Edit: Just had a thought - what are your Firewall settings on the Netgear router? You might want to try temporarily enabling the "Disable Port Scan and DOS Protection" option on the "WAN Setup" screen, if you have it?
good idea
my v4 randomly picked up port 3074 as a dos attack. i remember that i downgraded back a firmware version to be able to keep dos an port protection on
is there anything in the logs of the router saying 3074 port DOS
19-08-2009 7:53 PM
I disabled the firewall in the members section a few days ago but that didnt make any difference
Ahh! I will turn off the DOS protection and see if that makes a difference. I will test this later gents and get back to you.
Thanks for the ideas!
20-08-2009 12:03 AM
Let me know how you get on!
20-08-2009 12:17 PM
