Xbox 360 won't connect to xbox live
spamuel
For some reason my xbox 360 won't let me connect to xbox live but It is saying it's connect to my router and internet, I am using an Ethernet cable straight from the router to the console, I go to test xbox live connection it passes the first 2 stages but fails the connecting from internet to xbox live bit, I have tried everything the xbox forum has suggested but still no luck, could someone help me it would be much appreciated.
1 REPLY 1
adamwalker
Fixes: 221
Re: Xbox 360 won't connect to xbox live
Hi, have you tried rebooting the router?
I assume it's worked fine for you in the past?
 Adam Walker
