XBOX ONE - Worth Getting a new Router?
- Gaming
- XBOX ONE - Worth Getting a new Router?
03-11-2013 1:01 PM
Looking at the WiFi spec for XBone It appears to be dual band 2.4ghz & 5ghz. My current router is a Netgear DG834n (some years old now!). Do you think I would see much of an advantage in speed and coverage by replacing my router with a newer dual band model?
Any advice appreciated other than... You should bet a PC or PS4 yada yada...
Cheers
Peter
Re: XBOX ONE - Worth Getting a new Router?
03-11-2013 3:15 PM
As for Xbox One, it all depends on your allegiance and preference, if you are a Microsoft fan, get Xbox One, if you are under 12 and like Pokemon, get a Nintendo Wii U, or if you are one of these people who would buy used bog roll if Sony packaged and sold it to you, buy PS4! It's all about the games though really, at the moment there are several Xbone games I want, such as Kinect Sports Rivals, Killer Instinct, Fighter Within, Ryse, and eventually, Project Spark, whereas from the announced list of PS4 games, there's nothing I want, even if PS4 is £80 cheaper for the hardware itself.
03-11-2013 3:21 PM
03-11-2013 5:14 PM
If you wanted to improve your home network speed and range, then consider using powerline adaptors to connect you XBone to your router.
Another router related consideration is that Xbox one uses IPv6.
Until Plusnet eventually get around to rolling-out native IPv6, I don't know how well the DG834N will forward Teredo traffic (tunneled IPv6 over IPv4), although I would presume that the XBone would fallback to ordinary IPv4 - and just work the same as Xbox 360 does now.
03-11-2013 6:32 PM
http://www.speedguide.net/faq_in_q.php?qid=340
03-11-2013 10:09 PM
04-11-2013 12:33 PM
There's a few people I play games with on wireless and every night they d/c or lag with high ping. Surely if it occurs that often you'd think about getting ethernet or adapters.
04-11-2013 9:49 PM
Hopefully they will be fine, if they are then I would say a bit of a bargain as they are 500 instead of 200, have three ports each and a plug pass through.
12-11-2013 3:17 PM
Quote from: RichAllen I have the standard Plusnet router and Xbox Live is fast and works fine.
I think he was asking about routers not some fanboy drivel.
12-11-2013 10:35 PM
13-11-2013 5:03 PM
Quote from: meanalf ]
I mentioned the router! Any other problems with my post?
