XBOX ONE Nat Problems
neduk
Having some serious issues with Nat
always resetting to Strict
Any hints....?
Running the BT modem and a TP Link router
4 REPLIES 4
adamwalker
Fixes: 221
Re: XBOX ONE Nat Problems
Have you given this a try?
http://support.xbox.com/en-GB/xbox-one/networking/nat-error-solution
 Adam Walker
Mathias
Often best to port forward to get the NAT to open
neduk
So i tried the port forward and my internet connection stopped working!!
Ive tried the work around that you pull the triggers etc and it worked now we have had the update I doesn't work
nanotm
have you tried undoing the port forwarding etc and switching upnp on ?
upnp should just work although the router might need to be restarted to change the settings fully
