WoW Latency
- Gaming
- WoW Latency
WoW Latency
17-09-2009 5:06 PM
im on the plusnet pro package..been with plusnet around 3months now
also i have checked my local internet exchange and seems to be fine
Re: WoW Latency
17-09-2009 5:59 PM
which hop on a traceroute the high latency starting.
try a command prompt tracert to bbc.co.uk and post the results
Re: WoW Latency
17-09-2009 9:53 PM
over a maximum of 30 hops:
1 49 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 45 ms 27 ms 25 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 33 ms 27 ms 30 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 28 ms 28 ms 62 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 29 ms 32 ms 26 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 26 ms 38 ms 35 ms 212.58.238.149
7 45 ms 28 ms 30 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Re: WoW Latency
17-09-2009 10:02 PM
they dont look to bad for what looks like interleaved line
do you know the ip of the wow server you use and have problems with? if so try running one to that
http://www.egn.com.au/wiki/WoW_Server_IP_Addresses
not sure if this link will help you find the ip or not as dont use wow or pc to game. you can allways run wireshark why playing the game to find the ip's used http://www.plus.net/support/broadband/troubleshooting/wireshark.shtml
this are my fastpath pings
Quote Tracing route to bbc.co.uk [212.58.224.138]
1 3 ms 1 ms 1 ms 10.0.0.1
2 27 ms 18 ms 19 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 26 ms 23 ms 18 ms vl604.thn-gw1.plus.net [84.92.4.169]
4 17 ms 18 ms 17 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 20 ms 17 ms 19 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 17 ms 19 ms 19 ms 212.58.238.149
7 19 ms 18 ms 18 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Re: WoW Latency
17-09-2009 10:56 PM
this is what i got from running a tracert to the server im playing on
Tracing route to 80-239-181-97.customer.teliacarrier.com [80.239.181.97]
1 95 ms 90 ms 99 ms dsldevice.lan [192.168.1.254]
2 33 ms 39 ms 26 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 161 ms 117 ms 241 ms vl303.thn-gw2.plus.net [84.92.3.178]
4 47 ms 29 ms 25 ms ldn-b4-link.telia.net [213.248.84.197]
5 28 ms 36 ms 31 ms ldn-bb2-link.telia.net [80.91.254.21]
6 59 ms 35 ms 37 ms prs-bb2-link.telia.net [80.91.254.211]
7 42 ms 48 ms 33 ms prs-b4-link.telia.net [80.91.251.114]
8 47 ms 38 ms 47 ms prs-nant-ks51-geth0-1.telia.net [213.248.98.74]
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * *
Re: WoW Latency
18-09-2009 10:11 AM
It doesn't look fantastic from the office either:
C:\Documents and Settings\jbailey>tracert 80.239.181.97
1 <1 ms <1 ms <1 ms ge-0-2-0-7.fhw-cr02.plus.net [84.93.216.85]
2 6 ms 6 ms 6 ms at0-3-0-pte-gw2.plus.net [212.159.1.91]
3 6 ms 6 ms 6 ms 80.239.193.141
4 6 ms 6 ms 6 ms ldn-bb1-link.telia.net [80.91.248.90]
5 14 ms 14 ms 13 ms prs-bb1-link.telia.net [80.91.254.209]
6 14 ms 13 ms 13 ms prs-b4-link.telia.net [213.248.65.222]
7 14 ms 14 ms 14 ms prs-nant-ks51-link.telia.net [80.91.249.66]
8 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
Re: WoW Latency
18-09-2009 10:13 AM
B.
Re: WoW Latency
18-09-2009 3:08 PM
Re: WoW Latency
18-09-2009 6:24 PM
Game tends to lag up after a few hours of playing but if I reset my router it tends to give some respite however temporary it is.
Here's a traceroute I did to the server I play on to help shed anymore light on what's going on.
D:\Documents and Settings\Craig>tracert 206.16.235.80
Tracing route to 206.16.235.80 over a maximum of 30 hops
1 1 ms 1 ms 1 ms 192.168.0.1
2 285 ms 57 ms 442 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 441 ms 57 ms 443 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 453 ms 468 ms 61 ms xe-1-2-0-0.lon20.ip4.tinet.net [213.200.79.233]
5 126 ms 456 ms 126 ms xe-10-0-0.nyc30.ip4.tinet.net [89.149.184.101]
6 516 ms 480 ms 500 ms 12.118.94.45
7 507 ms 509 ms 486 ms cr2.n54ny.ip.att.net [12.122.130.166]
8 473 ms 532 ms 530 ms cr2.wswdc.ip.att.net [12.122.3.38]
9 513 ms 493 ms 511 ms 12.122.134.1
10 523 ms 529 ms 504 ms 12-122-254-98.attens.net [12.122.254.98]
11 479 ms 524 ms 498 ms mdf002c7613r0002-gig-12-1.wdc1.attens.net [63.24
0.192.142]
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Re: WoW Latency
18-09-2009 6:37 PM
Re: WoW Latency
18-09-2009 8:14 PM
@johnpayne - I would recommend that you do a Wireshark capture to check that the traffic is being prioritised correctly.
B.
Re: WoW Latency
18-09-2009 8:34 PM
Re: WoW Latency
18-09-2009 8:43 PM
It sounds like your line is experiencing high error rates, which in turn is leading to high retransmit rates, and thus high pings.
However, the most 'usual' explanation is high download rates - is your router wireless, and is it suitably secured?
B.
Re: WoW Latency
18-09-2009 10:32 PM
but i dont not actually play off the wireless end of it
i use the main computer thats wired
Re: WoW Latency
19-09-2009 6:07 PM
