WoW Gateway Problems
Hi All,
I have been having some issues connecting to WoW recently.  It would let me log ok then just get stuck at the character loading screen.  After much investigation this seems to be related to a specific Plus gateway - 195.166.128.27.  I have only been tracking this for a couple of weeks so the findings are hardly conclusive but everytime I have this isse I check which gateway I am connected to and it is always .27.  If I then disconnect and reconnect until I get a different gateway I can get into WoW again no problem.  When it gave me the same .27 gateway on a reconnect I did try WoW but it failed again.
So far my successful gateways have been:
195.166.128.80
195.166.128.72
195.166.128.123
The only unsucessful one is:
195.166.128.27
Anybody seen anything similar?
