Wireless Router
freefall
Wireless Router
So i'm thinking about getting a new wireless router, but this time i'm making sure it's compatible with Xbox =D.
Just wondering what you guys use and are they any good?
Also i don't want one too expensive, as i don't get paid until the end of the month.
FreeFall
4 REPLIES 4
Chris
Legend
Fixes: 169
Re: Wireless Router
Hi again Smiley
Personally I use a speedtouch 585v6 but I have my XBOX wired in. We did have a PS3 wireless on it without any problems. There are occasionally some good deals on wireless routers here so may be worth keeping an eye on.
johnjarram
Re: Wireless Router
i use netgear DG834G never had any problems and never had to use port forwarding with it either
i can stream music from my pc to my xbox and play games on xbox live at the same time
freefall
Re: Wireless Router
I was thinking about the Linksys WRT55AG because instead of just having the g and b channel it has the a one as well. I think from my understanding that i will get better connectivity when i go wireless on the Xbox (£50 that i dont want to spend on the adapter  Cry )
Has anyone heard of this one and is it any good?
iainmacmillan
Re: Wireless Router
personally, i would use a Netgear unit, either the DG834G or GT if you want a cheaper option, or the best is the DG834PN, which is what i have now, with the 6 internal aerials, and VPN pass-thru for work.  Should be able to pick that up for £65-75
http://www.amazon.co.uk/Netgear-DG834PN-RangeMax-MIMO-G-Wireless/dp/B000BRYOQ8/ref=sr_1_1?ie=UTF8&s=...
http://www.microdirect.co.uk/(11878)Netgear-Rangemax-DG834PN-MIMOADSL-Router-Firewall.aspx
http://www.dabs.com/productview.aspx?Quicklinx=3VZ5&CategorySelectedId=11177&PageMode=1&NavigationKe...
most games work fine without changing the config, but i do tweak the router, and add all my game & application ports on for the different programs i use.  I also have the latest firmware to make it ADSL2 compliant, though my exchange's 21CN upgrade is not due until 2011....:(
