Windows wireless laggy pings
Oldjim
Fixes: 63
I am sure all you experts know about this but I just spotted it in another forum and it may be of assistance
http://www.counterfeitculture.com/how-to/how-to-fix-windows-wireless-polling-lag/
In order for Microsoft to deliver their seamless roaming experience, WZC must actively maintain a list of networks within radio range. It accomplishes this by programmatically polling for available networks every sixty seconds with the probe request sequence. In situations — such as the home or office — where roaming is not required, the user has no need of an updated network listing. Nevertheless, the end-user is guaranteed a period of high latency and packet loss every sixty seconds. While such a design philosophy does little to interrupt the experience of browsing, downloading or email-retrieval, it is obvious and debilitating for more latency-sensitive applications such as gaming.
While the issue has persisted with considerable evidence to warrant a closer look, Microsoft maddeningly denies any issue. As early as 2004, Microsoft’s lead product manager in Microsoft’s Windows division remarked that “[They] don’t have data that suggests Windows XP drops wireless connections more than any other system.” He goes on to say that “Wi-Fi configuration in Windows XP is much different and easier than in previous versions.” In the interim, hundreds of hotfixes and numerous service packs have left the presented issues unresolved.
4 REPLIES 4
Fixes: 1,480
Re: Windows wireless laggy pings
Gaming over wireless on any platform is woeful and should be banned.
James
Along with PS3's.
Fixes: 1,480
Jealousy doesn't become you Mr Bailey
scootie
i use WLAN optimizer to stop the auto searching off windows no ping spikes for me every 30 seconds or so
you can also disable the wlan auto config service to get the same affect
