Ways of getting better pings?
- Gaming
- Re: Ways of getting better pings?
19-02-2009 10:32 PM
I tried turning Inter Leaving off, but my line is very old and it kept tripping out.
Is there any other way I can try to reduce pings to servers?
20-02-2009 12:58 PM
...Is this something that can be changed? or has it already been changed....he's gone from 100 pings to 20 now ^^
20-02-2009 1:07 PM
If switching interleaving off didn't work for you I don't think there is much else to try.
20-02-2009 3:25 PM
but it just kept cuttin my net out, as we on a very old copper wire
20-02-2009 3:58 PM
http://www.samknows.com/broadband/search.php
20-02-2009 11:22 PM
the main key to stable fast path long lines is to take a hit on sync rate and lower this abit from what the dslam will sync at.
easyest way to do this with out dmt tool program ect is to do a resync at the noiseist time of day for your line. this will make your line better cope the following day when noise gets high again as your router synced at them line condtions so is unlikely to drop.
if you post your stats from you router ie atten, snr sync rates
my 51db atten line stays connected for weeks on end if i sync it my self with dmt tool to get a ip profile 2500kbps if i let dslam sync me in day time it will sync pushing ip profile 3000-3500 and some times 4000kbps but never stays synced long enough to get the that ip profile
26-02-2009 6:03 PM
I have same problem with ping. 50ms UK servers and 80ms-90ms other in Europe.
What is mtu? Can I change my mtu?
26-02-2009 6:37 PM
do you have interleaving on or off?
26-02-2009 6:40 PM
26-02-2009 6:45 PM
27-02-2009 7:48 PM
27-02-2009 9:34 PM
Interleaving
Interleaving is a form of error correction that helps to improve the stability of high-speed broadband. You currently have interleaving switched on.
While improving stability, interleaving can increase ping times. This can cause problems for online gamers. For this reason, we offer the ability to turn interleaving off.
Warning! Turning interleaving off may reduce the stability of your broadband connection. We recommend leaving it turned on. If you turn interleaving off, there is no option to turn it back on again.
Is not there option to turn interleaving back on if I will have problem without interleaving?
28-02-2009 7:44 AM
28-02-2009 8:59 AM
28-02-2009 10:36 AM
