WOW Patch 3.2
- Gaming
- WOW Patch 3.2
WOW Patch 3.2
05-08-2009 3:03 PM
I go through the login (Slow) and get chucked out at retrieving character info.
Anyone else having problems? Even reaching the website?
Re: WOW Patch 3.2
05-08-2009 3:15 PM
No surprise there then.
I can get into www.wow-europe.com (using my PlusNet connection at the moment), realm status says Darkspear should be up, but my realm (Nordrassil) is still down. In fact quite a few are still down. Though the truth and realm status can differ.
I don't have the game installed here to try.
Looks like they're still having problems with quite a few of the realms at the minute, they should sort it out in time.
Re: WOW Patch 3.2
05-08-2009 3:32 PM
Target Name: forums.wow-europe.com
IP: 80.239.186.24
Date/Time: 05/08/2009 15:27:38
1 0 ms 0 ms 0 ms my.router
2 18 ms 10 ms 11 ms lo0.plusnet.thn-ag1.plus.net
3 12 ms 11 ms 10 ms vl703.thn-gw1.plus.net [84.92.4.241]
4 10 ms 9 ms 9 ms ldn-b4-link.telia.net [213.248.84.201]
5 N/A N/A 9 ms ldn-bb2-link.telia.net [80.91.251.14]
6 N/A 17 ms 17 ms prs-bb1-link.telia.net [80.91.254.209]
7 N/A N/A 16 ms prs-b1-link.telia.net [80.91.250.249]
8 17 ms 18 ms 17 ms prs-rosy-s50.telia.net [80.91.251.90]
9 * * * [-]
10 * * * [-]
11 * * * [-]
Destination not reached in 35 hops
it flounders after telia
ITs the Forums i am trying to reach
Re: WOW Patch 3.2
05-08-2009 3:36 PM
Re: WOW Patch 3.2
05-08-2009 4:03 PM
Quote Forum Maintenance Notification
This forum is currently undergoing maintenance, please check back at a later time.
Re: WOW Patch 3.2
05-08-2009 5:43 PM
How to rectify.
1) Quest Helper has been updated.. go to Curse and download the latest version.
2) If you run Cartographer and you get something like .cartographer\libs\LibRockConfig-1.0\LibRockConfig-1.0. Then go here http://wow.curse.com/downloads/wow-addons/details/librockconfig-1-0/download/372749.aspx and download the zip ..replace in World of Warcraft\Interface\AddOns\Cartographerr\libs\LibRockConfig-1.0 with the folder in the zip.
3) when you first log in, click on the Addons button at the lower left of the character creations screen. When the addons screen comes up, again look to the lower left and you will see where it says "Load out-of-date addons". Make sure it's checked and you should be good to go.
Re: WOW Patch 3.2
06-08-2009 4:08 AM
Re: WOW Patch 3.2
06-08-2009 4:09 PM
Known problem the guild told me.
I should check for updated versions really .. probably going to have to now as the patch'll break everything
Re: WOW Patch 3.2
07-08-2009 4:08 PM
All me addons are stuffed, having to update them now!
Re: WOW Patch 3.2
07-08-2009 10:15 PM
Sell them before the price goes down on the AH!
