Thompson 585v7 Port Forward Problem
- Gaming
- Thompson 585v7 Port Forward Problem
16-04-2010 10:02 PM
Re: thompson 585 v7 portforward problem
16-04-2010 10:21 PM
port forwarded to 81. from 81 to 81 both options on any and the the following fields left blank. Tried with upnp on and off. Restarted the router. None of these work. i still get this error from canyouseeme.org
Error: I could not see your service on 87.114.187.20 on port (81)
Reason: Connection timed out
Nothing i do works and there are no instructions on the internet that work about how to port forward with this router. What should i do?
Re: Would you replace a D-Link with a Thompson?!!!
16-04-2010 11:07 PM
That way we can ask members to post if they have every been able to port forward with plusnet and if so, how they did it.
Plusnet Don't Support Port forwarding. Or XBOX LIVE
16-04-2010 11:18 PM
Does XBOX Live Work for you with unrestricted NAT? If so once again please state your router model and method of success. I look forward to a solution to this problem for everybody. Thanks in advance
Edit: Xbox Live works please click here: http://192.168.1.254/cgi/...&tid=ASSIGN_PUBL_ADDR
and add your xbox to the DMZ to allow for open NAT settings
Plus net do not support port forwarding and when i rang the techsupport line they said they were not qualified to teach me how to port forward i would have to ring thompson. This is the first ISP I have ever used where the tech support tell me they are not qualified to give instructions on port forwarding. And they also tell me that they only stock 1 router the Thompson DG585v7.
jim:red Excessive formatting removed as this is classed as shouting mod:end
Re: Plusnet Don't Support Port forwarding. Or XBOX LIVE
16-04-2010 11:30 PM
Never used XBOX Live, so I can't help with that !.
16-04-2010 11:38 PM
Port forwarding works fine.
Was using a Thomson router provided by Plusnet. Now using a Billion BiPac 7800N.
Can you edit your post. its quite disgustingly large, (im colourblind, and im finding it hideous to read.)
My post here may help you
And yes, it is not PNs job to tell you how to port forward. They only provide the router - not the tech support for it. - The files there are manuals for the router in question.
Also, ensure the broadband firewall is switched off in your plusnet members centre.
*edit* - afterthought portforward.com should help you with what you are after. However, putting your xbox in a DMZ will remove all need for portwarding.
16-04-2010 11:42 PM
[edit]
I have been to port forward the instructions are not clear. They lack to mention what if anything you should put in the port trigger and trigger protocol settings. I have read numerous posts from other users of this router and there are no concise instructions as of yet on how to do this. The manual also does not provide instructions. I will be extremely happy for someone to point out that i am incorrect and show me that there are indeed instructions so i can fix uTorrent and dc++ and the other applications i need port forwarding for.
16-04-2010 11:44 PM
Quote Thus plusnet internet does not by default support either xbox live open NAT or port forwarding because the Thompson router simply will not port forward.
Yes, it does.
Please read the links in my last post.
16-04-2010 11:48 PM
you can port forward.
you can use a DMZ
you can use VPN software
The thomson router is more than adequate as a router - the interface is a little slow when under heavy load - it does handle many connections simultaneously pretty well. - as a Free router, its not bad.
@ Adept. theres no need for the 'forum rape' - for a start, posting at 11pm - your not likely to get a response from plusnet (9-5 hours for most staff) - and most of the people on the forum are customers - like yourself - they will help - just be patient.
Quote is by far the hardest to configure router i have ever used
I agree, the interface isnt the best - my favourite so far has been the Dlink interface - but still ... cant have everything for free eh ?
16-04-2010 11:48 PM
I suggest you read the forum rules:
Quote Avatars and Signatures
The forum moderators reserve the right to ask any member to change their Avatar and/or Signature, should they feel that it is inappropriate, or does not comply with the following guidelines;
Avatar size should be limited to 80 x 80 pixels and a maximum file size of 40kB
Use of the Plusnet (Force9, Free-On-Line, Metronet) Logo as an Avatar is reserved for staff.
Signatures should use no more space than 4 lines of standard sized text would, this includes any blank lines and images you choose to use. Image based signatures should be limited to 80 x 560 pixels and a maximum file size of 40kB.
17-04-2010 12:07 AM
Ok i have gone to the firewall settings and it says the setting is protected and unchangeable even though i am logged in as the admin. I have turned off the upnp and port forwarded to port 81 and also assigned the MAC address of my wifi card to the Application that is using port 81. Still on canyouseeme.org it is flagging a time out. I know the daemon is running and listening for the connection. What am i doing wrong? This is by far the most difficult to configure router i have ever used. As far as using telnet and learning a whole new command set that is unacceptable.
17-04-2010 12:18 AM
Here, best link i can find quickly
i'd delete the rule you already made. - Also - some insight into the application your using would be appreciated - it all helps find out what the problem is.
17-04-2010 12:38 AM
17-04-2010 1:10 AM
I guess the question now remains, has any plusnet member had any success forwarding ports with the Thompson DG585v7 router and if so, then how did you achieve it. Maybe then we can clarify this question at last.
17-04-2010 1:18 AM
Using several ports (including web, mysql, RDP)
Again: What application are you trying to run on Port 81 - its a standard port used for SHTTP could be having a wobbler if your trying to use something like utorrent through it - (as it will probably have quite a low connection limit on that port)
