Thinking of buying Xbox and Kinect - which one?
- Gaming
- Thinking of buying Xbox and Kinect - which one?
30-01-2012 10:00 PM
I'm quite intrigued by the recent Xbox dashboard update and I'm tempted to invest in one soon, along with the Kinect to act as a home entertainment hub in the main.
I'm using a Wii for that purpose at the moment, but it's hardly HD and it's only got iPlayer on it. Ironically the iPlayer and itvplayer aren't on xbox yet, although I gather they're on the way. I'm sure I'll make use of it for a bit of Skyrim and a few kinect games to keep the family entertained too.
Now my main question is that there are 2 main models of xbox by the looks: The 4GB and 250GB. Given the above usage, do I really need to invest in the 250GB hard drive version or not?
I'm on Fibre value, so I'll have to watch out for usage if we get heavily into the on demand stuff, but that's another issue...!
6 REPLIES 6
Re: Thinking of buying Xbox and Kinect - which one?
30-01-2012 10:09 PM
Hi, If you want to install games to your Hardrive and you think you will download a lot of DLC etc I suggest you go for the 250GB one, Or wait to see what the Wii U has to offer later this year.
Netflix Is available on the Wii now.
If life gives you lemons, make lemonade.
31-01-2012 9:21 AM
Just in case you didn't realise, you can't transfer files onto the Xbox, so it's no good as a replacement for a current media system based off mp3s/flac files etc. I bought one especially to use as a media centre as well as for some games and didn't realize.
You can stream from another machine on your network, but the idea was for it to store the media as well 😕
Kelly Dorset
Broadband Service Manager
31-01-2012 10:39 AM
31-01-2012 11:13 AM
Not quite the same as decommissioning my old NAS which was the plan
Kelly Dorset
31-01-2012 5:38 PM
Thanks. I'm getting the impression that I was along the right lines as I wasn't planning on exporting all my media files onto it, but streaming over wireless anyway. Linking up a flash drive sounds an ideal option if I have a change of heart.
I presume any other game saves (not that there'll be many) will be save to the cloud?
01-02-2012 4:59 PM
Game saves will save on your HDD or you can save them on the cloud through the xbox, Just remember If you plan on playing skyrim there will be no point playing it from the HDD if you go for the 4GB console, Skyrim takes up about 3.5GB.
