Teamspeak 3 server and Minecraft server
- Gaming
- Teamspeak 3 server and Minecraft server
21-01-2014 9:21 PM
My Broadband is firewall is OFF.
Someone help me!
Re: Teamspeak 3 server and Minecraft server
22-01-2014 12:36 PM
I've run a TS3 server from home before without any problems.
22-01-2014 2:16 PM
22-01-2014 5:08 PM
Also, can you connect to both from within the network?
22-01-2014 5:23 PM
22-01-2014 6:09 PM
22-01-2014 7:26 PM
Quote from: dvorak If the OP was posting from their home account then ts3.ciscolabs.co.uk doesn't resolve to their home IP. It current resolves to 67.215.65.132 which is somewhere in the states...
You've entered the name server wrong. It's tsp3.ciscolabs.co.uk not ts3.
23-01-2014 12:55 AM
23-01-2014 12:35 PM
24-01-2014 12:38 PM
Is there a particular error message that you're receiving?
Are you hosting it on Windows or Linux?
24-01-2014 3:34 PM
25-01-2014 12:20 PM
2014-01-25 10:26:06.132651|INFO |ServerLibPriv | | SystemInformation: Windows Server 2008 R2 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
2014-01-25 10:26:06.257451|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
2014-01-25 10:26:06.257451|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
2014-01-25 10:26:06.522651|INFO |DatabaseQuery | | checking database integrity (may take a while)
2014-01-25 10:26:06.756652|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
2014-01-25 10:26:12.403862|INFO | | | Puzzle precompute time: 5585
2014-01-25 10:26:12.419462|INFO |FileManager | | listening on 0.0.0.0:30033
2014-01-25 10:26:12.591062|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
2014-01-25 10:26:12.591062|INFO |Query | | listening on 0.0.0.0:10011
2014-01-25 12:06:13.798803|INFO |CIDRManager | | updated query_ip_whitelist ips: 81.174.xx.xx
This is the Server log.
28-01-2014 1:39 PM
I mainly use Linux for my hosting needs - if you're really struggling I could simply set you up a TS3 server on my dedicated that I rent (based in France)
Can you connect to the server locally? i.e through the 192.168.1.x IP?
Cheers.
28-01-2014 3:31 PM
I can connect locally to either IP addresses, But I can't connect to my WAN IP. Also I would to host it at home, Thanks for the offer.
28-01-2014 3:42 PM
For instance, tsp3.ciscolabs.co.uk doesn't resolve so you haven't correctly added an A or CNAME record to the the domain record. ciscolabs.co.uk and www.ciscolabs.co.uk resolve to 208.109.181.202 (p3slhwst12.shr.phx3.secureserver.net) and serve basic pages for your domain.
Have you tested the changes you've made to name records?
Are you testing access from a machine that isn't on your LAN? What happens if you specify you PN IP address rather than 'tsp3.ciscolabs.co.uk' in your tests to confirm you've got the right ports open?
