Teamspeak 3 Losses connection
- Gaming
- Teamspeak 3 Losses connection
22-02-2015 12:06 PM
I keep getting issue's with Team speak when no one else on has my issues. (on the TS server)
Basically what happens is, people start to sound really static and i lose connection and can rejoin about 5 minute's later.
Has anyone experienced this and know a fix?
Tried some fixes like check DDOS protection, Firewall SPI no luck.
Thanks.
Re: Teamspeak 3 Losses connection
22-02-2015 3:08 PM
which version have you ? i remember a update a few days back .
22-02-2015 5:59 PM
22-02-2015 6:28 PM
22-02-2015 6:41 PM
22-02-2015 10:27 PM
i have a xonar DX card and Qpad QH90 headset , only problems last week before update ?? on Odd occasions.
are you using onboard sound ?
23-02-2015 7:10 PM
24-02-2015 12:05 PM
Start--> Run --> ping www.google.com -t
This will run a ping nonstop until you either close the command prompt window or hit control and c at the same time. Try it without TS running, then run it with TS running as you have issues and see what happens. If no changes then it's an issue with your teamspeak software. If you start seeing packets dropping then i'd try a driver reinstall. If no luck after that I'm out of ideas without restoring windows from scratch
06-03-2015 10:19 AM
06-03-2015 12:36 PM
13-03-2015 4:20 PM
At a loss of what it could be. I'd have to see if it happens again tonight. If it does somehow I don't think its a software issue somehow.
13-03-2015 9:09 PM
16-03-2015 9:13 AM
From memory there's also a way to see connection status within TS3, although that may only be the admins that can see it.
16-03-2015 9:17 AM
did you not install the updates when they were released then ?
if it works flawlessly through your mobile I would stick to using it that way, then you can see who's talking each time, which helps greatly when someone starts doing funny things .......
16-03-2015 8:50 PM
Quote from: nanotm @fort
Mobile version was affected tonight too. I had the latest installed on the pc originally anyway its just the night in question when I re-installed over the top of it, it started working properly again but some nights the packet loss is still happening.
Chris, everything else works fine. Speed Testing gives full speed, torrents download fine etc. Just Teamspeak seems to be affected at times. Using Wireshark it shows that traffic is being managed correctly. But I haven't tested Wireshark when Teamspeak is having trouble. When I get a chance I'll test and let you know.
