TV or dedicated monitor for console gaming?
- Gaming
- TV or dedicated monitor for console gaming?
24-04-2014 10:36 PM
What do you use for console gaming, a TV or a dedicated monitor?
If you don't game on a console you don't have to reply.
I use the 40" TV for my PS3.
Re: TV or dedicated monitor for console gaming?
24-04-2014 10:39 PM
24-04-2014 10:42 PM
25-04-2014 7:40 AM
25-04-2014 9:07 AM
25-04-2014 9:39 AM
Have the PC plugged into the Mini Displayport socket, and the PS3 into HDMI.
Have sound coming out of my Hi-Fi next to them - for the PC I use a USB to Optical converter, and connected the output audio jacks to audio in for the HDMI.
So I switch the monitor and Hi-Fi inputs when I want to change. Not that I play the PS3 very often.
25-04-2014 11:34 AM
Quote from: Ben I have an A/V amp .....
I managed to smuggle a Yamaha RX-V767 and a pair of 3 foot tall speakers into the house while the wife was at work yesterday, set it all up and she didn't notice there was anything different when she got home - result !
25-04-2014 12:40 PM
Quote from: rongtw i have best of both worlds my sons xbox is connected to his 26" monitor which has freeview built in
i can connect most things to it
Call me thick if you like (I won't be offended) but what is the difference between a monitor with freeview built in and a TV?
25-04-2014 1:24 PM
Nice, mine on the other hand tries to invade the man-cave to listen to her CDs! Not on my watch
25-04-2014 1:34 PM
The downside of being an electronics engineer is you always find something you could improve on and end up rebuilding stuff from scratch. At some point I'll build a system I'm happy with (from scratch !) but in the meantime the 767 (which cost me £25 as it was broken when I got it) will have to suffice
25-04-2014 1:53 PM
25-04-2014 4:45 PM
but they will have a HDMI,,, so i have my old PC connected to DVI ,Xbox on HDMI
25-04-2014 11:55 PM
26-04-2014 1:55 AM
26-04-2014 9:45 AM
