Suddenly today been getting a pleas ensure your firewall permits UDP ports
zwitterelf
This never happened to me with the pluss one router, only the old technicolour router..
I dont know how the settings work, and I cant browse the game and apply settngs like the old router did... it gives you a drop down of games, but Warframe is not on it.
warframe.com/en/firewall
i tried rebooting router , computer etc... and it still does not fix this... i might try disable the router firewall completely until i can get this right.
2 REPLIES 2
geek26
Re: Suddenly today been getting a pleas ensure your firewall permits UDP ports
Sorry to here about your problems, someone should be able to review this for you shortly but just a quick note I would advise against turning off your router firewall this really isn't recommended.
James
Gus
That is a DE problem, it's a remote server bug that crops up, usually when they get DDosed only started in last 2 or 3 days was fine last week
FTTP 500 regrade from Tues 28th November
