Strange request - whats the worst connection you can give me
TerryCTR
As the title states, I need the cheapest connection available that will give the highest ping and have my line strangled at peak times but still cover my usage from playing on xbox live.
Ive really had enough of BO2 now and I even tried streaming bbc i player at the same time in the hope of gaining a sh*t connection like most others playing but it didnt do anything.
Can I have this asap please as until they release a patch I don't need a gaming line with interleaving off etc
Terry
12 REPLIES 12
rogadodge
Re: Strange request - whats the worst connection you can give me
Grin
Kelly
Fixes: 9
We are plotting.      Cool
Kelly Dorset
Ex-Broadband Service Manager
Fixes: 1,483
try running a torrent rather than iPlayer, that seems to do the trick here - are you on fibre?
Kelly
Fixes: 9
I would hope that wouldn't work.  Unless you had a pro profile.
Kelly Dorset
steroberts89
If your router supports it, maybe use a vpn like https://www.ipredator.se/ or if you can set your xbox to route through it connecting to the tor network?
Fixes: 1,483
maybe i've just not been afflicted by the lag comp then Smiley
Chris
Legend
Fixes: 169
Terry,
I've PM'd you with a test we'd like to try.
flaminmoses
chris im in the same boat as terry (the getting shot before ive gone round the corner boat)
pm me please with this test !!!
Kelly
Fixes: 9
Where did we get to on this?
Kelly Dorset
Grff
I know how the original poster feels.  I upgraded to fibre just before BO2 was released and got around a 35ms ping to places like the BBC website, so latency is quite low on the line.
Great i thought, black ops should be good, and ill be able to kill people better than when i had adsl.
However, in BO2 it often gives me the host (which for any other game gives you a distinct advantage), but for some reason when it does, can i heck kill anyone.  Shoot and shoot, often shooting first, and still I die.  Maybe it's just treyarch can't make a good game.
I often find those at the top of the score board are the ones with the three bar connections now.
flaminmoses
its not just bops2
i get this on fifa as well.
when i upgraded to the 80/20 service my ping also got better.
ive had 0ms registered!!!
average about 10ms
fifa seems to switch after the 10 minute mark and it makes the connection harder to play
sometimes its like that from the word go.
the amount of times ive wanted to smash the disc up lol is quite a lot
Kelly
Fixes: 9
My current thinking is that problems with Fifa are down to them.  The reports we get of problems with it are so inconsistent for it to be routing or traffic management problem 😕
Kelly Dorset
