Strange gaming since elected to switch to unlimited
- Gaming
- Strange gaming since elected to switch to unlimite...
24-01-2013 9:24 PM
Since I switched to unlimited my gaming has been strange, before I could allways get the drop on people but now I can empty a full mag into them with no hit detection whatsoever. BF3 PC. Also the game seems to be running at half speed as though I am running through treacle. I have done a few restarts to try a different gateway and at the momment I am on ptw-ag04.
My stats all look the same.
Download speedachieved during the test was - 11.25 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 12.44 Mbps
Estimated line speed:10Mb (This may vary between 8Mb and 11.5Mb) - Checked on 2012-12-19 10:22:29
Current line speed: 11.9 Mb
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 14104 1203
Noise Margin 4 5
Output power(dBm) 12 20
Attenuation(dB) 28 15
Infact this is the highest my rate @14104 has been since I switched to ADSL 2+.
Re: Strange gaming since elected to switch to unlimited
24-01-2013 9:32 PM
What I saw was in game pings going crazy with Lotro and streams 4OD/Iplayer/5player stuttering
24-01-2013 9:39 PM
IIRC BF3 is having a few server problems this week too that may be impacting things.
24-01-2013 9:48 PM
I have just built a new computer so BF3 and ARMA 2 are the only games I have on at the moment and ARMA 2 is laggy by default lol, so unfortunately I can't say anything about other games. I will put MOH tier 1 on and see how I go.
Thanks.
24-01-2013 10:48 PM
I was on ag04 here is the info
So i jumped gateways and im now on ap06 and getting my correct speeds and ping again .. below
24-01-2013 11:14 PM
I will swap gateways in the morning so I don't take too much of a speed hit mate.
25-01-2013 7:29 AM
25-01-2013 8:47 AM
We need the full gateway name, ie PCL-AG06 etc as the first part identifies which data centre it's in.
If this happens again can you check that?
26-01-2013 4:41 PM
29-01-2013 10:48 PM
I don't know if this relates but my old board had the marvell yukon ethernet driver and this one has intel. ?
30-01-2013 8:15 PM
30-01-2013 9:08 PM
Can you do a traceroute to the beeb and a speedtest or two?
Ex-Broadband Service Manager
30-01-2013 9:19 PM
30-01-2013 9:26 PM
C:\Users\James>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.2.1
2 13 ms 13 ms 12 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184
3 20 ms 12 ms 12 ms link12-central10.pcl-gw02.plus.net [84.93.249.86
4 25 ms 12 ms 12 ms xe-1-2-0.pcl-cr02.plus.net [212.159.1.6]
5 18 ms 13 ms 18 ms ae2.pcl-cr01.plus.net [195.166.129.6]
6 * * * Request timed out.
7 12 ms 12 ms 14 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
8 * * * Request timed out.
9 13 ms 14 ms 16 ms ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
10 16 ms 18 ms 17 ms 132.185.255.60
11 12 ms 13 ms 14 ms 212.58.241.131
Trace complete.
2 19 ms 13 ms 13 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184
3 16 ms 40 ms 21 ms link12-central10.pcl-gw02.plus.net [84.93.249.86
4 25 ms 19 ms 43 ms xe-1-2-0.pcl-cr02.plus.net [212.159.1.6]
5 24 ms 24 ms 25 ms ae2.pcl-cr01.plus.net [195.166.129.6]
7 15 ms 12 ms 12 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
9 39 ms 26 ms 30 ms ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
10 18 ms 14 ms 19 ms 132.185.255.60
11 44 ms 41 ms 19 ms 212.58.241.131
Trace complete.
Before when I watched the BBCi player without it buffering, I was watching it wireless with my PS3, this time I watched it on my computer which is wired. As i said before I can't understand it. I have just built a new computer and the ethernet drivers and all the chipset drivers are up to date. I have tried a different router and that was the same, lagging really bad in BF3.
30-01-2013 10:28 PM
- Gaming
