Starcraft 2 traffic priority.
Oxslow
I am having some problems with SC2. This is not every game but enough to be annoying.
The game comes up with a message that says the game is waiting for me, sometimes I get dropped then other times I can play for a little bit with lag before I get dropped.
After looking at a wireshark capture of a game that did not drop me. I noticed not all my traffic was titanium some of it was gold. Could this be what is causing the problem?
In the mean time I will try and get a wireshark  capture of a game where I get dropped.
2 REPLIES 2
bobpullen
Fixes: 307
Re: Starcraft 2 traffic priority.
Quote from: Oxslow
If you can that would be very helpful. If it's getting misclassified then we can raise a Change Control to have things corrected.
Oxslow
I got dropped from a game tonight here is the router stats and a wireshark capture
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 800 Kbps, Downstream rate = 4831 Kbps
Link Power State: L0
Mode:                  ADSL2
Channel:                Fast
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):      3.2            5.8
Attn(dB):      49.5            29.0
Pwr(dBm):      0.0            12.8
Max(Kbps):      5400            788
Rate (Kbps):    4831            800
                        G.dmt framing
K:              148(0)          101
R:              4              16
S:              1              1
😧              64              8
                        ADSL2 framing
MSGc:          60              12
B:              147            100
M:              1              1
T:              1              1
R:              4              16
S:              0.9735          4.0000
L:              1249            234
😧              64              8
                        Counters
SF:            11444864                10213945
SFErr(CRCErr):  732            0
RS:            755361044              3462383
RSCorr:        555836          10
RSUnCorr:      8138            0
HEC:            543            0
OCD:            1              0
LCD:            0              0
Total Cells:    2095047215              1527369
Data Cells:    65254756                12401
Drop Cells:    0
Bit Errors:    0              0
ES:            10258          0
SES:            40              2
UAS:            154            0
AS(Uptime):    183852
INP:            0.81            2.18
PER:            16.06          18.00
delay:          15.57          8.00
OR:            32.86          8.00
Bitswap:        17245          331
Total uptime:  967106
Total time = 1 days 4 hours 42 min 25 sec
SF  = 60046881
CRC = 26796
LOS = 0
LOF = 0
ES  = 10258
Latest 1 day time = 4 hours 42 min 25 sec
SF  = 1054883
CRC = 78
LOS = 0
LOF = 0
ES  = 52
Latest 15 minutes time = 12 min 25 sec
SF  = 46391
CRC = 3
LOS = 0
LOF = 0
ES  = 2
Previous 15 minutes time = 15 min 0 sec
SF  = 56069
CRC = 2
LOS = 0
LOF = 0
ES  = 1
Previous 1 day time = 24 hours 0 sec
SF  = 5378433
CRC = 361
LOS = 0
LOF = 0
ES  = 189
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF  = 56007
CRC = 3
LOS = 0
LOF = 0
ES  = 2
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF  = 56006
CRC = 9
LOS = 0
LOF = 0
ES  = 5
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF  = 56069
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Showtime Drop Reason:  8000
Last Retrain Reason:    8000
http://www.oxslow.plus.com/dropped_sc2.pcap
