Routers
Gledge
Routers
Does anyone here know of any good routers to use on plusnets network. mainly for GAMING and HOME networking.
As my almost £800 for the next two years does not cut it for them to SUPPLY good reliable router that Frecking WORKS!
Im getting really p!ssed that they seem to take my money then laught at me for doing so.
insted of "Plusnet, we'll do you proud"
it should be, "plusnet frecking you proudly!"
4 REPLIES 4
Gus
Re: Routers
I got rid of mine and replaced it with a Billion 8800NL http://www.broadbandbuyer.co.uk/products/18474-billion-bipac-8800nl/ It made some games[Warframe/Borderlands 2/pre sequel] no longer reported strictnat out of the box, were as the Technicolour I had to telnet into it to fix it.  That and my ADSL connection has never been so stable, other than a power outage and BT work, I have not lost connection since the end of September
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Mathias
Re: Routers
Got this router for my fibre connection a month ago and found it great for gaming.
Port forwarding is a breeze and works reliably. Have strong stable connection. Have also enabled QoS to ensure gaming traffic gets top priority. There are lots of features on this router.
Managed to get it for £80 from amazon.
http://www.broadbandbuyer.com/products/15031-d-link-dir-868l-e/
Gledge
Re: Routers
Thanks guys for your prompt responce! will look into them!
Crazy Crazy Crazy
All4One
Re: Routers
@mathias look at the fancy cylindrical beast!
