Random Grrrrrrrrrrrrrrr
- Gaming
- Random Grrrrrrrrrrrrrrr
25-10-2009 11:22 AM
Re: Random Grrrrrrrrrrrrrrr
25-10-2009 11:40 PM
Eve has always been large and takes me a zillion years to download. What package are you on? Most packages give free usage after midnight till 8am so that wouldn't eat into it atall
26-10-2009 8:39 PM
26-10-2009 8:41 PM
I assume jojo is refering to Eveonline which is a MMORPG (Massive Multiplayer Online Role Playing Game) Here's a link for it.
http://www.eveonline.com/
If it's anything like World Of Warcraft then it's going to be massive as Warcraft is about 12GB on initial download if you don't have the DVD's.
26-10-2009 11:25 PM
26-10-2009 11:55 PM
27-10-2009 9:19 AM
Have you considered moving to Pro for a month?
Everything would come down at line speed, including steam downloads
27-10-2009 10:23 AM
27-10-2009 10:30 AM
Have you always had a speed of 0.5mb? Or has it been faster in the past?
27-10-2009 10:33 AM
27-10-2009 10:34 AM
Are you doing the usual things like trying your router into the master socket with all of your other telephone devices unplugged? It's possible that you might be able to eek a bit more out of your line.
If you're at home I'll be happy to call to run you through a few suggestions of things you could try to make things a bit better.
27-10-2009 10:38 AM
edit @ above - see James if you leave us who will we have to phone us about gaming? It's terrible, you'll have to educate Bob or Mand to the joys of MMO's!
27-10-2009 10:49 AM
Download speedachieved during the test was - 441 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :672 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
@ dgwebb... No i took off my iplate, it seemed to lose connection when that was attached, worked finr for the first day or so then I would start having connection problems...
27-10-2009 10:55 AM
27-10-2009 10:59 AM
I've just given Jo a ring and we've concluded that it's about as good as it will really get because of line length sadly
