Problems playing PS3 games online
- Gaming
- Problems playing PS3 games online
30-04-2009 10:12 PM
Can anyone help?
Re: Problems playing PS3 games online
01-05-2009 11:33 AM
I tried to narrow it down to either being Plusnet or EA, but got nowhere. Loads of websites and forums tell you about opening ports, putting router in DMZ. I tried everything and it still doesnt work.
01-05-2009 11:49 AM
and then run wireshark to sniff the ps3 packets you will be able to tell if fifa is getting the right prioity on the PN (which it should)
If all is o.k then the blame can stick with EA like it does for so many other games they think there servers are o.k running.
http://www.plus.net/support/broadband/troubleshooting/wireshark.shtml
01-05-2009 12:51 PM
Quote from: mrmarkus1981 Cant speak for Streetfighter, but the FIFA 09 issue has been around for absolutely ages. I have the same problem, i can play a friend sometimes and sometimes not, are you getting the 'game session unavailable' message?
Yes I'm getting that message, its just so frustrating...
01-05-2009 1:36 PM
I could unplug my PS3, wire it up to my PC and post the stats, but i shouldnt have to, i paid Sony £350 for the machine, EA £30 for the game and i pay Plusnet £20 p/m for my broadband.
IMO - one of the aforementioned companies should diagnose and fix any problems that occur!
01-05-2009 1:47 PM
and the other two companies i dare you try and get a reposnse from them
01-05-2009 1:48 PM
01-05-2009 1:57 PM
And my final opinion on the matter is sonys ps3 is the biggest sucker
get you self a payed for gaming console network that doesent have to be run by volunters
01-05-2009 2:05 PM
01-05-2009 2:14 PM
micro have are money in the bank to spend on anti hack improvments. watch this space
01-05-2009 2:49 PM
01-05-2009 9:47 PM
02-05-2009 5:07 PM
02-05-2009 6:12 PM
my set up is ethernet from xbox to pc
local lan and wireless adapter on pc bridged
if your using wireless on your pc this is how to bridge the 2
to bridge on vista got to network and share. then manage network connections and highlight your local lan and wireless then right click and choice bridge.
some times to get it to work you need to make sure the lan and wireless is not in use ie disconnect your wireless and pull the cable out of your lan before bridging them
