Problems connecting to servers battlefield 3 xbox 360 please help!
LukeAger
Re: Can you provide me a router that will work with battlefield 3 xbox 360 please?
It worked straight out of the box. I didn't even need to change any of the router settings or mess with the ports.
Quote from: Kelly
I'll get Matt to have a deeper look at your router tomorrow to see if he can see anything odd.  (He knows lots about routers).
Id see what happens when Mat looks into this. If you have not already reset the router using the pin hole on the back i would suggest trying this. You may have some luck if the routers settings are not correct.
Fixes: 5
and check that your router has the latest firmware installed.
Plusnet FTTC 80/20 IPv4/30, Hurricane Electric 6in4 IPv6/48, Pulse8 landline & calls, SamKnows 600N
Vigor 130 modem, pfSense 2.4.4-p3 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
firemaster50
Going to reset router then check latest firmware and post back results, fingers crossed!.  Thanks for the help so far  Smiley
firemaster50
reset router with pin changed nothing still same message you have lost connection to session!
dick:quote
firemaster50
Fibre optic being installed on the 22nd with new router lets hope that cures it  Cry
mattturner
Hi Firemaster,
I've made a change to your router, please could you see if this has fixed it?
Thanks,
Matt
dick:quote
firemaster50
Dam my impatience, I reset the router before I see this post so its still not working lol
[Moderator's note by Dick (Strat):  Full quote of preceding post removed, as per Forum Rules ]
Fixes: 7
Re: Problems connecting to servers battlefield 3 xbox 360 please help!
Set as it press the little reset button?  or just power off and on again?
Kelly Dorset
Broadband Service Manager
firemaster50
Quote from: Kelly
I pressed the little reset button with pin m8
Fixes: 7
Doh.  That would have removed the changes Matt did 😕
Kelly Dorset
mattturner
I've reapplied the change. Just FTI (and in-case you factory reset again!) I've applied game mode and included an extra port, port 53.
Let me know if you notice any difference.
Matt
firemaster50
will do when i get home in luton visiting at the moment m8 thanks Smiley
firemaster50
Quote from: Matt
Matt
I could not connect with the xbox or pc after this, on lap top it said local only had to reset with pin again m8, to post on here  Cry still getting that fibre wednesday if that dont work who knows what, throw game out window maybe final resolution lol, ive followed the guide to open nat again so i can play modernwarfare 3 m8
Fixes: 7
Did you restart the router before resetting it?
Kelly Dorset
mattturner
Hi Firemaster,
Sorry about that, I'm not sure what happened.
The command you need to run to mimic my actions is:
:connection bind application=CONE(UDP) port=88
Let me know if this helps (if not I'll call you and we can discuss  Smiley )
Matt
