Problems connecting to servers battlefield 3 xbox 360 please help!
- Gaming
- Problems connecting to servers battlefield 3 xbox ...
10-02-2012 4:55 AM
done this for battlefield 3 xbox 360 cant connect to servers still please help works with modernwarfare 3 but uses a different port please help i tried everything at my wits end with this router now!
This is what ports are used taken from Ea's site:
f you are playing on Xbox 360, please enable the following online ports on your connection:
TCP: 53, 88, 3074
UDP: 53, 88, 3074
Re: Problems connecting to servers battlefield 3 xbox 360 please help!
10-02-2012 11:22 AM
I've applied a config change to your router. Hopefully that should cure that for you. Let me know how it goes.
Jojo
10-02-2012 6:26 PM
10-02-2012 10:20 PM
10-02-2012 10:23 PM
Host Name IP Address Hop Ping Time Ping Avg % Loss Pkts r/s Ping best/worst
dsldevice.lan 192.168.1.254 1 2ms 1ms 2% 107 / 110 1ms / 3ms
lo0-central2.pcl-ag02.plus.net 195.166.128.236 2 18ms 25ms 0% 109 / 110 17ms / 164ms
gi1-24-221.pcl-gw01.plus.net 84.92.6.40 3 18ms 27ms 2% 107 / 110 16ms / 189ms
po4.pcl-gw02.plus.net 212.159.1.129 4 19ms 25ms 2% 107 / 110 16ms / 201ms
* Unknown Host * 195.50.122.129 5 55ms 26ms 1% 108 / 110 16ms / 69ms
ae-52-52.csw2.London1.Level3.net 4.69.139.120 6 17ms 24ms 0% 110 / 110 16ms / 48ms
ae-59-224.ebr2.London1.Level3.net 4.69.153.141 7 17ms 21ms 6% 103 / 110 16ms / 67ms
ae-42-42.ebr1.NewYork1.Level3.net 4.69.137.70 8 90ms 89ms 3% 106 / 110 85ms / 126ms
ae-4-4.ebr1.NewYork2.Level3.net 4.69.141.18 9 86ms 89ms 0% 109 / 110 85ms / 135ms
ae-3-3.ebr2.Washington1.Level3.net 4.69.132.89 10 93ms 95ms 0% 109 / 110 90ms / 166ms
ae-62-62.csw1.Washington1.Level3.net 4.69.134.146 11 100ms 97ms 5% 104 / 110 91ms / 154ms
ae-13-60.car3.Washington1.Level3.net 4.69.149.5 12 222ms 103ms 1% 108 / 110 91ms / 291ms
ELECTRONIC.car3.Washington1.Level3.net 4.79.169.74 13 257ms 100% 0 / 108
fert07-eqx-iad.ea.com 159.153.224.230 14 92ms 106ms 2% 105 / 108 92ms / 316ms
meav5-pub.pt.iad.ea.com 159.153.226.105 15 98ms 96ms 1% 106 / 108 92ms / 202ms
10-02-2012 10:26 PM
Jojo please can you give me more help with my battlefield 3 post?
13-02-2012 3:05 PM
13-02-2012 3:08 PM
I've merged your new thread into your existing one as it will still have a high profile and get noticed.
13-02-2012 3:12 PM
The fix Jojo ran last time should be working alright, do you use any torrents by any chance? If you have been doing, rebooting the router should sort the gaming out - please let us know if it does help. Best bet is to reboot using the button in the router's interface though
13-02-2012 3:18 PM
13-02-2012 3:35 PM
13-02-2012 3:39 PM
http://www.joystiq.com/2011/10/29/psa-how-to-open-your-ports-for-battlefield-3/
13-02-2012 6:37 PM
Can you provide me a router that will work with battlefield 3 xbox 360 please?
14-02-2012 3:20 PM
Thanks in advance.
Re: Can you provide me a router that will work with battlefield 3 xbox 360 please?
14-02-2012 4:15 PM
- Gaming
