Problems connecting to servers battlefield 3 xbox 360 please help!
- Gaming
- Battlefield 3 still dont work now on fibre connect...
- « Previous
- Next »
Re: Problems connecting to servers battlefield 3 xbox 360 please help!
20-02-2012 5:55 PM
Let me know if this helps.
Battlefield 3 still dont work now on fibre connection please help?
22-02-2012 2:23 PM
22-02-2012 2:55 PM
A few questions:
- Have you added any port forwarding rules to the router?
- Are you playing on XBOX or PC?
- If XBOX, is your XBOX Live account still active and not closed/expired for any reason?
- If XBOX can you play any other games online through XBOX live?
- If PC have you got the latest battlelog browser plugin?
- If PC can you access the server browser?
22-02-2012 3:24 PM
Quote from: Chris This is very odd, I've got the game on both PC and XBOX (yes I know, overkill!) and have played it on both platforms. I'm on Plusnet Fibre and have used both the Netgear router we supply and a different Netgear router, both of which were standard set up out of the box and had no port forwarding rules set up.
A few questions:
I have done nothing to this new router straight out the bx, its xbox 360. xbox live fine can play modernwarfare 3 no problem? HELLP!
22-02-2012 3:29 PM
adie:quote
22-02-2012 3:45 PM
22-02-2012 4:09 PM
22-02-2012 4:26 PM
22-02-2012 5:15 PM
Quote from: Chris So it's after installing the patch that you are having problems connecting? Are you making sure that you have the Back 2 Karkand add-on and if you don't then make sure you aren't trying to play on one of those maps.
I dont have that addon keeps saying you have lost connection to session what ever i try join its not happening still think its time to bin the dam game now!
22-02-2012 5:22 PM
22-02-2012 5:40 PM
Quote from: firemaster50
Your a genius im such an idiot been trying to connect to karkand maps, had to reconfigure as this is all was getting on server lists
, I so sorry everyone its the numpty this end that got it wrong.
Thanks mate u are a star Top man respect to you
- « Previous
- Next »
- Gaming
