Problems connecting to servers battlefield 3 xbox 360 please help!
firemaster50
I have done what it says in the post to increase gaming compatability with thomson tg585v8 but it does not help with this game cant connect to servers seems a port issue:
done this for battlefield 3 xbox 360 cant connect to servers still please help works with modernwarfare 3 but uses a different port please help i tried everything at my wits end with this router now!
This is what ports are used taken from Ea's site:
f you are playing on Xbox 360, please enable the following online ports on your connection:
TCP: 53, 88, 3074
UDP: 53, 88, 3074
55 REPLIES 55
jojopillo
Re: Problems connecting to servers battlefield 3 xbox 360 please help!
Hi firemaster50,
I've applied a config change to your router. Hopefully that should cure that for you. Let me know how it goes.
Jojo Smiley
firemaster50
Still the same message you have lost connection to session everytime i try connect to a server Cry
firemaster50
Is there anything else that can be done or do i need a different router?
firemaster50
dont know if this may help its wat ea asked me to do but no help?
Host Name                                      IP Address        Hop    Ping Time  Ping Avg  % Loss    Pkts r/s  Ping best/worst
dsldevice.lan                                  192.168.1.254    1      2ms        1ms        2%        107 / 110  1ms / 3ms
lo0-central2.pcl-ag02.plus.net                  195.166.128.236  2      18ms        25ms      0%        109 / 110  17ms / 164ms
gi1-24-221.pcl-gw01.plus.net                    84.92.6.40        3      18ms        27ms      2%        107 / 110  16ms / 189ms
po4.pcl-gw02.plus.net                          212.159.1.129    4      19ms        25ms      2%        107 / 110  16ms / 201ms
* Unknown Host *                                195.50.122.129    5      55ms        26ms      1%        108 / 110  16ms / 69ms
ae-52-52.csw2.London1.Level3.net                4.69.139.120      6      17ms        24ms      0%        110 / 110  16ms / 48ms
ae-59-224.ebr2.London1.Level3.net              4.69.153.141      7      17ms        21ms      6%        103 / 110  16ms / 67ms
ae-42-42.ebr1.NewYork1.Level3.net              4.69.137.70      8      90ms        89ms      3%        106 / 110  85ms / 126ms
ae-4-4.ebr1.NewYork2.Level3.net                4.69.141.18      9      86ms        89ms      0%        109 / 110  85ms / 135ms
ae-3-3.ebr2.Washington1.Level3.net              4.69.132.89      10    93ms        95ms      0%        109 / 110  90ms / 166ms
ae-62-62.csw1.Washington1.Level3.net            4.69.134.146      11    100ms      97ms      5%        104 / 110  91ms / 154ms
ae-13-60.car3.Washington1.Level3.net            4.69.149.5        12    222ms      103ms      1%        108 / 110  91ms / 291ms
ELECTRONIC.car3.Washington1.Level3.net          4.79.169.74      13    257ms                  100%      0 / 108
fert07-eqx-iad.ea.com                          159.153.224.230  14    92ms        106ms      2%        105 / 108  92ms / 316ms
meav5-pub.pt.iad.ea.com                        159.153.226.105  15    98ms        96ms      1%        106 / 108  92ms / 202ms
firemaster50
I have heard about setting up a static ip and forwarding ports , any ideas on this please?
firemaster50
Jojo please can you give me more help with my battlefield 3 post?
Still at a complete loss here?  Cry
Strat
Fixes: 565
Moderators Note
I've merged your new thread into your existing one as it will still have a high profile and get noticed.
orbrey
Hi firemaster50,
The fix Jojo ran last time should be working alright, do you use any torrents by any chance? If you have been doing, rebooting the router should sort the gaming out - please let us know if it does help. Best bet is to reboot using the button in the router's interface though Smiley
firemaster50
Im going to try rebooting the router seems funny modernwarfare 3 works fine but not this will post back in a bit, thanks and let you know!
firemaster50
Re booted router still same message when trying to connect to servers :  You have lost connection to session is this unsolveable?.  Or can you send me a router that will work with this game please?
orbrey
Not sure if you've tried it (sorry if you have) but does this page help at all? Looks like the guy was having the same issues:
http://www.joystiq.com/2011/10/29/psa-how-to-open-your-ports-for-battlefield-3/
firemaster50
Tried that never worked I give up its been 2 weeks, can you reccomend another router please?
firemaster50
Can you provide me a router that will work with battlefield 3 xbox 360 please?
I have been trying for 2 weeks to connect to ervers with no luck, followed all advice, including port forwarding, setting xbox to a static ip address forwarded ports for this game as well, no luck this  router works with modern warfare 3 but battlefield 3 no way!.  I need a new router hopefully you can provide me one that will work with this game plusnet?, if not do i have to go buy another, advice please, read previous posts please.
Thanks in advance.
adamwalker
Fixes: 221
Re: Can you provide me a router that will work with battlefield 3 xbox 360 please?
I'm wondering if this might help: http://community.plus.net/library/gaming/increasing-gaming-compatability-with-the-thomson-tg585v8-xb...
 Adam Walker
