Ports remained blocked with Tompson TG585
- Gaming
- Ports remained blocked with Tompson TG585
02-06-2012 3:38 PM
Hi, I'm having trouble with ports and the Tompson TG585 v7.
As far as I can tell I'm forwarding the ports correctly:
But nothing can seem to see it, shields up reports it blocked:
The Plusnet firewall is off, the router firewall is off and windows firewall is off. I'm using windows 7.
Is there anything else I can do?
2 REPLIES 2
Re: Ports remained blocked with Tompson TG585
04-06-2012 9:29 PM
Hi BigDaz.
Click on the 'Assign a Game or Application to a local network device' underneath the Pick a task...
add the Game/App to the device you want to port forward.
Hope this helps.
Hope this helps.
04-06-2012 9:36 PM
Thanks. Is it assigned to my PC.
I've tried assigning it to the name of the computer and the IP, it just seems to ignore it.
