Port forward help please on a TG585 router
- Gaming
- Re: Port forward help please on a TG585 router
24-02-2012 9:39 PM
I have set up the correct Xbox live ports; 53, 80,88,1863,3074 in the game and application centre. I named the application "Xbox live" and assigned it to the Xbox console with a fixed IP address.
No matter what i do i can not get the ports to open, I have tried all sorts and although the ports are assigned to the Xbox to be open they just will not open. I have used the port forward checker and all i get once ive tested them is this;
IP address; **********************
Ping result; we were not able to ping your router!
Port result; your port is not open or not reachable!
How can I get the ports open and to stay open?
jim:green title changed after spitting off from original thread mod:end
Re: Re: shocked at the level of poor service i am receiving (phone and broadband)
24-02-2012 9:44 PM
24-02-2012 10:29 PM
24-02-2012 10:42 PM
24-02-2012 10:49 PM
its a thompson gateway 585 V8.
oldjim; I had no idea what was going on then, my post kept vanishing so i thought there was a problem with my browser. hence the posts and threads
24-02-2012 11:17 PM
This is driving me insane, why the hell won't it work!
25-02-2012 12:16 AM
25-02-2012 9:55 AM
I have done everything in this guide; http://portforward.com/english/routers/port_forwarding/Thomson-Alcatel/TG585v8/Xbox_Live_360.htm
Still no joy, I skipped no steps, set up a static IP on the PC and the Xbox if that helps.
25-02-2012 10:42 PM
27-02-2012 5:07 PM
Especially if you're experiencing NAT issues.
Regards,
29-02-2012 2:52 PM
Since I sorted this out I have had a solid 4 bar connection on any games I have played online and suffered minimal lag (the lag problems I have had have been the lag compensation which is a known fault with the like of cod etc) and the connection speed has not dropped once aswell as having sub 20 millisecond ping times. Hardly any packet loss either, I am really happy with the connection at the moment.
