Port Forwarding
- Gaming
- Port Forwarding
Re: Port Forwarding
30-05-2013 12:00 PM
Re: Port Forwarding
30-05-2013 12:14 PM
Ex-Broadband Service Manager
Re: Port Forwarding
30-05-2013 12:24 PM
Re: Port Forwarding
30-05-2013 1:02 PM
It's not the easiest thing though. I'll talk to the guys.
Re: Port Forwarding
30-05-2013 1:42 PM
Re: Port Forwarding
30-05-2013 2:22 PM
Re: Port Forwarding
01-06-2013 11:09 AM
Re: Port Forwarding
14-06-2013 2:45 PM
STILL Getting disconnected from the game, this is just getting a bit silly now. Thanks for all the help, but i am going to cancel and go elsewhere. Also I will be seeking legal advice as to the charge to come off PlusNet too - £60 I will be charged when the internet that I paid for is NOT capable of gaming in which I got it for.
I won't be paying that either.
Re: Port Forwarding
14-06-2013 3:12 PM
I've made a few adjustments to your line to see if this will help improve things, previously you mentioned that the issue seemed to have gone away otherwise I would have been looking to help you.
Could you let me know if you see any difference when you next try?
Re: Port Forwarding
20-06-2013 1:10 PM
no difference. Still getting disconnected - I can't see a resolution to the problem anytime soon... Just not capable of gaming by the sounds of it.
Re: Port Forwarding
30-06-2013 11:31 AM
Re: Port Forwarding
01-07-2013 9:30 AM
Would it be possible for you to create a ping graph?
Re: Port Forwarding
03-07-2013 1:57 PM
yes the same problem. Nothing seems to have worked at all. Will read up on this Ping thing you posted about.
cheers.
Re: Port Forwarding
03-07-2013 2:02 PM
Re: Port Forwarding
03-07-2013 2:33 PM
