Plusnet Pro for gaming?
dannyboy1121
Anyone here using Plusnet Pro for gaming? As I'm hooked on Elite Dangerous at the moment, I thought I'd have a pop at trying Pro in the hope To reduce latency (not that the standard service is that bad).
Any good experiences? How quick does it come in to effect?
2 REPLIES 2
ghos7em1
Re: Plusnet Pro for gaming?
if you are on fibre i wouldnt use it as it will make your connection worse.its more for adsl
Gus
Save some money and do a wireshark capture and submit it http://community.plus.net/library/faults/using-wireshark-for-data-capture/
FTTP 500 regrade from Tues 28th November
