Plusnet One Hub Firmware Update/Rejecting connection?
Qunite
Re: Plusnet One Hub Firmware Update/Rejecting connection?
Not had a chance to test properly since been busy. will update after 2 days solid playing as i sometimes go a whole day with 0 issues then some days i get it 8-9 times a day.
Its mostly when I am doing content like arenas, teleporting etc since I am instance hopping so once I spend some more time I will update you.
Thanks for spending the time to try help me with this.
Fixes: 1,602
No problems. Fingers crossed it’s sorted!
Fixes: 1,602
You guys still seeing issues or has this been resolved?
Feel free to join the conversation over Here Smiley
Qunite
Since those latest changes you made I have not had any more timeouts so hopefully this is the solution for everybody.
Thanks for the support.
Fixes: 1,602
Glad to hear that! Thanks for letting us know.
