Plusnet Fibre Extra with Onlive
- Gaming
- Plusnet Fibre Extra with Onlive
- « Previous
- 1
- 2
- Next »
Re: Plusnet Fibre Extra with Onlive
06-10-2011 3:03 PM
Our own internal test line on the Extra and Value products is showing it working fine, but I want to see if that is replicated outside of our office.
Ex-Broadband Service Manager
06-10-2011 5:02 PM
Quote from: tracycrossan However, i have joined the Onlive service and its totally unplayable. The service will start but all games are pixelated an sluggish.
Matt and I have been investigating further today.. Some more questions. What do you mean by sluggish? Like low FPS? Or movement/actions seeming to not respond? Is the pixelation constant? Or does it look fine and then break up?
Could you get a screengrab of the issue?
06-10-2011 5:31 PM
I've put you on the Pro traffic management profile (as of 5 minutes ago)... perhaps you can let us know if the OnLive service improves?
Thanks,
Matt
06-10-2011 9:02 PM
I just logged on to OnLive (not for long) I had no problems, graphics fine and responsive. Mac client - update was required before I could logon might need a PC client upgraded?.
Mark
07-10-2011 9:36 AM
07-10-2011 11:52 AM
Result....... My Onlive is now perfect. The Pro add-on seems to have worked.
I also installed some software to reduce the latanecy on my network called LeatrixLatencyFix (http://www.wowinterface.com/downloads/info13581-LeatrixLatencyFix.html)
So one of the two did the job.
Can you confirm if the Pro add-on will incur an extra cost? (obviously i'd rather not pay anymore :P)
Thanks again.
07-10-2011 4:25 PM
I'm glad that this resolved your problems!
I doubt the latency reducer has done anything as there are no acknowledgement packets in the OnLive protocol.
The Pro Addon does incur a charge but we'll leave you on it until we fix this issue, we won't charge you.
We suspect the problem lies with the video stream coming from OnLive. The bandwidth required is 5Mbps however we limit the gaming traffic on your package to 5Mbps exactly. It may be that upping this bandwidth very slightly will fix the problem.
We'll be doing some more investigation next week and getting a fix prepared.
Enjoy your weekend with OnLive and be careful not to rack up too much usage 😉
Matt
07-10-2011 4:39 PM
I really appreciate your help.
If you could let me know when this fix will be applied so I can test it I would be grateful.
I'm not sure I could justify another £5 a month just for Onlive otherwise.
Tracy
12-10-2011 1:35 PM
We made a change yesterday to fix this and I've successfully tested it this afternoon. We've changed the rate limit from 5Mbits/s to 6Mbits/s for both Fibre Extra and Fibre Value.
Five minutes ago I changed your traffic profile back to the default Fibre Extra and I am confident that you'll not notice any difference with OnLive. Please could you let us know how you get on?
Thanks,
Matt
16-10-2011 8:11 PM
Quote from: tracycrossan I also installed some software to reduce the latanecy on my network called LeatrixLatencyFix (http://www.wowinterface.com/downloads/info13581-LeatrixLatencyFix.html)
i wouldn't of thought that would work with onlive as from what i can see only the log in process uses a bit of tcp, once logged in its all UDP including the control input packets
19-10-2011 5:06 PM
Just to let you all know, since Plusnet applied the gaming bandwidth increse from 5Mbits/s to 6Mbits/s Onlive is now perfect.
Thanks for the hard work Plusnet.....
27-10-2011 2:05 PM
30-03-2014 6:29 PM
Andrew
- « Previous
- 1
- 2
- Next »
