Plus net fibre, getting two xbox 360/ xbox ones with open nat
- Gaming
- Plus net fibre, getting two xbox 360/ xbox ones wi...
21-02-2014 9:47 AM
Hey all
My mate is thinking with going with plus net as I've had a good experience gaming with them, how ever I'm on a ADSL connection, he wants to go with fibre, my question is on fibre broadband does the stock router allow two xbox 360/ xbox ones to have a open nat out the box or will settings need to be changed?
1 REPLY 1
Re: Plus net fibre, getting two xbox 360/ xbox ones with open nat
21-02-2014 11:26 AM
You shouldn't need to change any settings.
The NAT Type should be 'Open' If, in the unlikely event, you have issues with the NAT Type, let us know on here and we'll take a look at it for you
P.S - Don't forget to get your friend to add your username into the referral section when he/she signs up so you get a monthly discount off your bill.
- Gaming
