Pings rised
- Gaming
- Re: Pings rised
Pings rised
01-11-2009 5:54 PM
Hi i've been playing this game for just under a year on plus.net and i got on well with nice low pings, which usually would show green here - http://i34.tinypic.com/jzu1pc.png - but recently everything has been yellow and red which shouldnt be whats gone wrong ?
8 REPLIES 8
Re: Pings rised
01-11-2009 5:58 PM
felt like dial up loading that up
have you wiresharked the game to insure the traffic prioity is still ok?
Re: Pings rised
01-11-2009 6:09 PM
im not sure if i have done this right becaus ei have never used wireshark. im a bit of a nub at this how do i attach it ? wont allow ==/
Re: Pings rised
01-11-2009 6:45 PM
pcap files wont attach on here. you can upload them to a file sharing website or do has ive done and take a snap shot.
your looking for the following that is circled in red, check the incoming pakets only as out going packets havint bein over the PN network yet so all say 0x00.
your looking for 0xa0 for gaming
Re: Pings rised
01-11-2009 7:38 PM
Re: Pings rised
01-11-2009 8:02 PM
i would submit that on a incorect traffic mangment ticket. insure any background traffic on your PC is kept to minum when taking the captue.
at first glance it only apperars that the sceencast port is being picked up as 0xa0 and the rest 0x80
Re:Pings rised
02-11-2009 3:08 PM
Hi amiller,
As ASBO says, if you attach that pcap file to a ticket (there's a path through the ticket wizard at http://contactus.plus.net - choose My Broadband Connection -> Broadband Gaming -> Adding a game to our traffic management system) we'll be able to get it added for you.
Hope that helps,
Hope that helps,
Re: Pings rised
02-11-2009 3:16 PM
how do i find out these three things then... and the game is already on the main list =/ ?
Re:Pings rised
03-11-2009 2:30 PM
If you submit a wireshark capture in a ticket and let us know the game that you are playing, we should be able to work out the rest for you.
