Ping
- Gaming
- Ping
Ping
04-06-2012 9:28 AM
Unfortunately for me I have a son who spends most of his time online gaming. I even join him occasionally when my Internet allows it! ( we both have xboxes) my problem is constant signal drops and really erratic signals. One minute it's fine the next it grinds to a halt. Also even when it's working at its best I'm still struggling to get pings below 50ms, usually more like 70ms. Which as most people on here will know, that's not a great gaming experience. I have recently added pro to my package and turned interleaving off through the website(yesterday) but it's still not made any difference. I have always had problems with my Internet. I guess I just don't have a great line. but there has been occasions where we both could play together and it worked great. I have changed all of my equipment a couple of times over the years and still can't get a reliable constant low ping connection. I suppose that's the holy grail for most people. I honestly do not care about speeds, just pings.
My speeds are 62ms ping dl 3.62 ul .36 . Any advice would be welcome.
Re: Ping
04-06-2012 9:35 AM
Re: Ping
04-06-2012 10:04 AM
If there is any info I can post up here to aid some assistance let me know and I'll do my best.
Re: Ping
04-06-2012 10:12 AM
Re: Ping
04-06-2012 10:23 AM
Re: Ping
04-06-2012 11:11 AM
Re: Ping
04-06-2012 12:17 PM
Re: Ping
04-06-2012 12:19 PM
Re: Ping
04-06-2012 1:27 PM
Re: Ping
04-06-2012 2:12 PM
Router Status
Hardware Version DGN2200
Firmware Version V1.0.0.36_7.0.36
GUI Language Version V1.0.0.25
Internet Port
<snip>
Domain Name Server
212.159.6.9
212.159.6.10
LAN Port
MAC Address C4:3D:C7:47:28:E4
IP Address 192.168.0.1
DHCP On
IP Subnet Mask 255.255.255.0
Modem
ADSL Firmware Version A2pB025c1.d21j2
Modem Status connected
DownStream Connection Speed 5120 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
Wireless Port
Name (SSID) chatburger
Region Europe
Channel Auto (11)
Mode Up to 300 Mbps
Wireless AP On
Broadcast Name On
System Up Time 23:59:41
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN pppoe 822432 737994 0 1892 10551 17:40:10
LAN1 Link Down -- -- -- -- -- --
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 300M 1757973 1622752 0 30199 3722 17:40:02
ADSL Link Downstream Upstream
Connection Speed 5120 kbps 448 kbps
Line Attenuation 48.0 db 28.5 db
Noise Margin 5.1 db 15.0 db
jim:green personally identifiable data removed mod:end
Re: Ping
04-06-2012 2:36 PM
Assuming that router works the same as my Netgear can you Telnet into it via a DOS Window and use this command adslctl info --stats
My Netgear gives this
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: INTR, Upstream rate = 992 Kbps, Downstream rate = 4640 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.1 7.0
Attn(dB): 51.0 25.0
Pwr(dBm): 19.3 12.7
Max(Kbps): 4928 1156
Rate (Kbps): 4640 992
G.dmt framing
K: 146(0) 32
R: 8 4
S: 1 4
D: 32 8
ADSL2 framing
MSGc: 59 10
B: 133 13
M: 1 8
T: 1 9
R: 10 16
S: 0.9863 4.0000
L: 1168 256
D: 32 8
Counters
SF: 840100 840108
SFErr: 11 95
RS: 57126830 14279830
RSCorr: 3927 205
RSUnCorr: 62 0
HEC: 7 39
OCD: 0 0
LCD: 0 0
Total Cells: 156290641 0
Data Cells: 1594213 0
Drop Cells: 0
Bit Errors: 0 0
ES: 93 0
SES: 3 0
UAS: 111 0
AS: 14282
INP: 1.09 2.00
PER: 16.02 18.00
delay: 7.89 8.00
OR: 32.44 7.11
Bitswap: 0 0
Total time = 11 hours 21 min 51 sec
SF = 2293503
CRC = 619
LOS = 2
LOF = 18
ES = 93
Latest 1 day time = 11 hours 21 min 51 sec
SF = 2293503
CRC = 619
LOS = 2
LOF = 18
ES = 93
Latest 15 minutes time = 6 min 51 sec
SF = 24131
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 15 minutes time = 15 min 0 sec
SF = 52982
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 0 sec
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52982
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52864
CRC = 0
LOS = 0
LOF = 0
ES = 0
Showtime Drop Reason: 8000
Last Retrain Reason: 8000
Re: Ping
05-06-2012 1:23 PM
Re: Ping
05-06-2012 1:30 PM
If you can use the tracert command in the DOS window to ntp.plus.net you should get something like this - my connection is interleaved
C:\Users\Jim>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.13.50]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 31 ms 31 ms 31 ms lo0-central1.pcl-ag06.plus.net [195.166.130.46]
3 38 ms 30 ms 33 ms gi7-6-611.pcl-gw01.plus.net [84.93.254.129]
4 31 ms 31 ms 30 ms vl63.pcl-lb01.plus.net [212.159.2.252]
5 31 ms 31 ms 31 ms cdns02.plus.net [212.159.13.50]
Trace complete.
Re: Ping
05-06-2012 2:17 PM
Tracing route to ntp.plus.net [212.159.6.10]
2 21 ms 38 ms 21 ms lo0-central1.ptn-ag03.plus.net [195.166.130.10]
3 22 ms 21 ms 20 ms gi2-8-311.ptn-gw01.plus.net [84.92.2.49]
4 21 ms 21 ms 21 ms vl55.ptn-lb01.plus.net [212.159.2.124]
5 20 ms 21 ms 26 ms cdns02.plus.net [212.159.6.10]
Trace complete.
C:\Users\Me>
mmmm...kinda seems to me like that is a good result?
Re: Ping
05-06-2012 2:27 PM
